11-24-2019, 11:47 AM | #265 |
Rep 399
11-24-2019, 12:03 PM | #266 | |
Rep 176
heizung_kuehlung is heat and ventilation Heizung is heat only Kuehlung is ventilation only |
12-01-2019, 08:38 PM | #267 |
Rep 343
Drives: '19 750i xDrive
Does anyone know if its possible to code Sport+ mode since it is standard on the Alpina B7? The 20mm drop would be nice.
12-01-2019, 08:47 PM | #268 |
Rep 176
12-02-2019, 12:46 AM | #269 |
Rep 8,364
12-02-2019, 09:49 AM | #271 | |
Rep 176
But look in BDC_Body for FesSportWorldMode1 change it to SportExpert Also in HU_NBT or HeadUnit for FES_Sport_Expert make it AKTIV If you have any more questions let me know |
LuckyW86.00 |
12-02-2019, 03:08 PM | #272 | |
Rep 399
And is Sport Plus just Sport with traction turned off? Thanks. |
12-02-2019, 03:38 PM | #273 | ||
Rep 176
The traction is not off on mine with SportPlus |
12-02-2019, 06:05 PM | #274 |
Rep 399
12-02-2019, 06:23 PM | #275 | |
Rep 176
https://www.bimmerfest.com/forums/sh.../topics/838460 When i turn my 750 into SportPlus DSC stays on. |
12-03-2019, 09:48 AM | #276 | |
Rep 399
12-03-2019, 09:49 AM | #277 | ||
Rep 176
12-17-2019, 04:35 PM | #278 |
Rep 25
Hey guys,
I am getting many PM’s regarding hands off driving with steering assist coding. Please note you need driving assistance plus package to code this option. I would like to share my knowledge with others so this information is available to anyone. CAF: SAS C_STA_ALC_handsoffgestchwausschaltgrenzeKmh C_STA_ALC_handsoffgestchwausschaltgrenzeMph C_STA_ALC_handsoffgestchweinsschaltgrenzeKmh C_STA_ALC_handsoffgestchweinsschaltgrenzeMPh Change werte value to desired speed (use hex converter) when hands is required on the wheel. Please be aware steering assist occasionally disengages without any warning. Use this coding on your own risk ! |
12-17-2019, 04:47 PM | #279 |
Rep 81
Hi, do you maybe know in which section of Bimmercode or in which particular device I can find if my G11 is in 'transport mode'? I have 2 problems that would point to it being on (first is the BMW Touch Command not popping pressing EJECT and EJECT seems to be blocked mechanically, second is that the perfume setting is resetting every time I start the car) and I would like to check that myself before visiting my service advisor.
12-21-2019, 10:20 AM | #280 | |
Rep 395
Any ideas? The car has iD7 |
12-21-2019, 10:35 AM | #281 |
Rep 25
I believe cars with ID7 uses camera to track your eyes, it don’t have touch sensor in the steering wheel, correct me if I am wrong
12-21-2019, 11:51 AM | #283 |
Rep 25
12-21-2019, 12:13 PM | #284 |
Rep 395
Yeah already tried it but no luck, the SAS2 module has very few options. For id7 might just be in another location.
There is thing called extended traffic jam assistant which allows the hands off the wheel for an extended period of time so if I can enable that or find where it is, it might do the trick. |
12-21-2019, 12:26 PM | #285 | |
Rep 25
12-21-2019, 12:30 PM | #286 |
Rep 25
Hello,
Maybe someone has G30 SAS2 cafd file with driving assistant plus package (5AT) to share, as I am trying to find sollution to increase ACC resume time to 30s on my G11. |
