12-21-2019, 12:38 PM | #287 |
Rep 395
I found C_HOO_Vorhanden is SAS2 and it is set to: nicht_vorhanden (which I assume it means switched off?)
Other options are vorhanden and UNK_PARAM_0 Was reading here: https://www.bimmerfest.com/forums/sh....php?t=1358929 that it won't work in EU countries so might be pointless I wonder if anyone in EU has managed to enable it. |
12-21-2019, 12:45 PM | #288 | |
Rep 25
12-22-2019, 11:12 PM | #289 |
Rep 72
I've coded few features with bimmercode using the OBDLINK MX+
I'm trying to figure out how I can code 2 features I think this might be in the expert mode but not sure and can't seem to find much information about it. 1. Turn signal (5 blinks) 2. door handle lights turn on in reverse Can anyone help me out? |
12-23-2019, 02:23 PM | #290 | |
Rep 25
rbndominguez0.00 |
01-10-2020, 06:19 AM | #291 |
Rep 107
On my daughters '12 528 I coded her fog lights to stay on with high beams using BimmerCode. I don't find a similar setting for that on my '16 750. I would assume it's there in expert mode however. Anyone know what that might be?
01-10-2020, 08:14 AM | #292 | ||
Rep 7,588
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-10-2020 at 08:19 AM.. |
01-15-2020, 05:02 AM | #294 |
Rep 891
Does anyone know which VO code I need to add for M sport steering wheel with shift paddles retrofit?
I have ran the wires need for the paddles and coded it, it works now but still I would like to add the VO code. Thank you |
01-15-2020, 08:51 AM | #295 | |
Rep 176
But here is a list of all the VO as of 2017 https://www.bimmerfest.com/forums/showthread.php?t=966607#/topics/966607 |
01-17-2020, 03:15 AM | #296 |
Rep 204
I'm pretty sure the answer to this will be no. However I'll ask anyway just incase it's possible.
I like the standard dash layout of Comfort/Adaptive on the digital cockpit. I also like the way sport mode is on the Alpina display. I've coded my car to have the Alpina dash layout. But went back to normal as wasn't overly enamoured about the standard dash layout. Is there a way to keep the normal dash layout and code just Sport/Sport individual to have the Alpina style layout? Or is only a case of either all standard or all Alpina. Thanks. |
01-18-2020, 12:24 PM | #297 |
Rep 5
I set all these parameters and setup iDrive to turn steering wheel and driver seat heat on below 48 degrees and the seat doesn't automatically come on. The steering wheel notifies me in the cluster that it is turned on but no front seat. I confirmed the above settings in Bimmercode. Thanks for any suggestions.
01-18-2020, 01:01 PM | #298 | |
Rep 204
MilehighM3915.00 |
01-18-2020, 01:46 PM | #300 | ||
Rep 162
BM
01-18-2020, 01:59 PM | #301 | |
Rep 204
01-18-2020, 03:04 PM | #302 |
Rep 5
I had to reset the temperature to come on and it automatically came on when my seatbelt was on, thanks for the tip. I will try again later tonight or first thing in the morning and see if it comes on automatically. This forum is awesome, thanks!
01-18-2020, 03:16 PM | #303 |
Rep 107
Thanks! Just searched NSW in Expert Mode on BimmerCode, change the NSW_AUS_BEL FL to not active and now the dogs stay on with the brights. Thanks for the help!
01-18-2020, 03:30 PM | #304 | |
Rep 176
01-18-2020, 04:23 PM | #305 | ||
Rep 162
BM
RaptorStrike61.50 |
01-20-2020, 02:01 AM | #306 | |||
Rep 204
I wasn't sure if it was due to regional variations. Mine has the auto heated and ventilated seats and steering wheel. But only the wheel works on its own. The heated ventilated seats only work once the seat belt is plugged in. |
bigmac f02+g1240.00 |
01-20-2020, 08:07 AM | #307 | ||||
Rep 162
BM
