The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Billet front diff housing with stronger gears
Reply
      08-28-2016, 02:15 PM   #23
OffensiveDriver
OffensiveDriver's Avatar
40
Drives: 2008 E92 335xi 6MT
Seems like there are guys drag racing high horsepower xi's who beat the snot out of them have failures. When your in the low 11's maybe high 10's day in and out, there are going to be some broken front diffs. It sounds like there are random failures as well but doesn't seem like a lot.
If you look on the xi forum, the documented failures seem to gear related. The fact that the fluid capacity is small doesn't help.
What would be really cool is an LSD solution for the xi front diff but that's probably too much to hope for…
M factory group buy ?
      08-28-2016, 08:43 PM   #24
Julian2485
Drives: Black lci e90 335 xdrive
Would love this
      08-29-2016, 12:48 AM   #25
RSTECH
Drives: e90 335i xdrive Msport
Interested
RIP10' A/W M-Sport-JB4-E85/93,50/50-BMS DCI-AR DP'S-Balck Kidney Grills-muffler delete-mm6 mesh18x8.5/9.5-Conti DWS 235/40 18, 265/35 18.
10'e90 a/w SportPackage-mhd e40 map- a/r dp's-vrsf charge pipe and tial blow off valve
95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, 2000 lbs.
      08-29-2016, 10:53 PM   #26
MFactory
MFactory's Avatar
Drives: E92 M3
Get me 10 confirmed buyers (with 50% deposit) and we can look into making one
      08-29-2016, 11:33 PM   #27
OffensiveDriver
40
Fi'n awesome. I'm not ready at the moment, maybe in a few months.
MFactory, what kind of unit do you propose to supply ? Interested. As mentioned, would love a front LSD for the xi. Possible if not cost prohibitive ?
      08-29-2016, 11:35 PM   #28
MFactory
MFactory's Avatar
Drives: E92 M3
Would be our Helical LSD
From looking at the images, doesn't look too complicated to do, so pricing should be same as our rear LSD
      08-30-2016, 12:30 AM   #29
OffensiveDriver
40
We should post in the XI section.
      08-30-2016, 07:16 AM   #30
reaper0995
Drives: 335xi
Are you wanting to just build the carrier portion to go into the factory housing, a billet diff of your own design, or one that fits into my design? I am designing mine around using the gm 7.2 gears since those can come in 3.08 and other gear selections, though unfortunately there isn't a 3.46 option for the autos
If you are wanting to design and build the entire front diff, then I wouldn't need to go any further on mine haha. If you wanted to work together I could do that too!
      08-30-2016, 09:35 AM   #31
OffensiveDriver
40
I believe what Mfactory is talking about is fitting a helical gear setup into the existing pumpkin, I cannot comment on it being stronger than the existing open setup but I imagine it could be depending on how much money is spent.
      08-30-2016, 10:22 AM   #32
MFactory
MFactory's Avatar
Drives: E92 M3
Yes, replacement Diff only (not the carrier, nor the Ring & Pinion).
It will definitely be stronger than the oem Diff (whether that matters or not), but what will definitely be of benefit is the increased traction.
      08-30-2016, 11:22 AM   #33
OffensiveDriver
40
Someone correct me if I'm wrong but the failures seem to be ring gear related ? If so, some kind of treatment of the ring gear to strengthen it would would potentially be beneficial ?
Apologies if I am threadjacking.
      08-30-2016, 01:22 PM   #34
reaper0995
Drives: 335xi
I think there's a lot of problems with the factory front pumpkin.. the carrier looks weak, the housing is split in an odd spot with nothing constraining the shear load other than friction, the spider gears look weak, the ring and pinion are relatively small, and the ball bearings seam to have more backlash than necessary. As the pinion gear starts to push load into the ring, it looks like it would be able to climb into a slight misalignment. Also not a lot of fluid volume.
      05-26-2017, 08:10 AM   #35
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Any updates?
      05-26-2017, 09:38 AM   #36
Glennyd
Drives: 2008 335
F Diff
I hope this can be made at a reasonable price point to hold 750-800 lbs. of torque. People are going to be building blocks very soon and this will be right in the wheel house as a necessity. I appreciate the efforts to date and look forward to see more.
      05-26-2017, 03:02 PM   #37
Julian2485
Yes we need a front lsd for our poor xi's
      05-27-2017, 02:03 AM   #38
DailyN54
Drives: 08 335xi, 08 335i
I'm kinda saddened that it's been almost a year since this thread started and no success, prototype, our anything. I would be willing to pay 3k for a strong front diff with a LSD. An Xi that can have 2 LSDs and can actually be lauched would be amazing.
      05-27-2017, 08:09 AM   #39
OffensiveDriver
40
Group buy.
      05-27-2017, 09:36 AM   #40
cortez08
Drives: 2008 335xi
If anyone can make a tested proven transfer case at a reasonable price put me down for the group buy.
      05-29-2017, 02:15 PM   #41
Julian2485
What about trying to fit a x5m front diff on our 3 xdrive or maybe swap the internals ?
      05-29-2017, 02:28 PM   #42
Maniac0908
Maniac0908's Avatar
Hmmm. I wonder if it would fit.
      05-29-2017, 10:12 PM   #43
LaxIan55
LaxIan55's Avatar
92
Drives: 335i E90 xdrive
Great idea, who has access to or knowledge of both diffs to figure out if anything is compatible.
      05-30-2017, 05:08 AM   #44
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
Here's what they look like
http://www.ebay.co.uk/itm/BMW-X5M-E7...-/182012076412
When you doppelkaplung you doppel your fun.
Reply
