      09-26-2010, 12:17 PM   #45
mbworldz
Drives: 2011 535i
You can buy them online.
http://cgi.ebay.com/ebaymotors/ws/eB...d=400154271200
Originally Posted by SAMLAMBO View Post
Where did you buy the bulbs from and just 2 bulbs needed? Can I buy it online?
      09-26-2010, 12:19 PM   #46
SAMLAMBO
Drives: 2010 BMW 730Li
Originally Posted by mbworldz View Post
Thanks! So it is the exact one they are having on bid now?
2012 BMW 740i
2011 Mercedes E250
2010 Lamborghini LP670-4SV
      09-26-2010, 12:21 PM   #47
mbworldz
Drives: 2011 535i
Yes it is.
      09-26-2010, 12:26 PM   #48
SAMLAMBO
Yes it is.
Thanks. So I just need 1 pair and all the lights will be white/blue correct? I dont have fog lights as my M kit deletes it.So jst for the main head lights I need this one pair correct?
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 12:30 PM   #49
mbworldz
Drives: 2011 535i
The package comes in a pair. But this is not for main head lights. This is a H8 socket. Its for the Angel Eye. It might fit the fog lights since the stock one is using H8 socket also.
But if you are talking about head lights. The low beam is using D1S Bulb.
      09-26-2010, 12:38 PM   #50
SAMLAMBO
Ok now I am confused. To make things simple, I want my lights to look just like yours. I dont need the fog lights as I dont have them anymore with the M kit. So what do I purchase?
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 12:43 PM   #51
mbworldz
Drives: 2011 535i
Just to clarify. You want to change your Angel Eye (daytime running light) or your low beam head lights ?
      09-26-2010, 12:48 PM   #52
SAMLAMBO
What did you do to yours? Just the Angel eye correct? Or did you do both to match? It would look wierd to have one in yellow and the other in bluish/white. Sorry but I am totally blur. I love how yours look in a few post above.
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 12:51 PM   #53
mbworldz
Drives: 2011 535i
I did the LED Angel Eye. I have a 8000K HID Kit installed on my Fog light. Also a 8000K D1S HID Bulb for my low beam head lights.
But I think you are asking for the Angel eye (daytime running light). So
Get this is ok.
      09-26-2010, 12:55 PM   #54
SAMLAMBO
Get this is ok.
Ok thanks and this is the one in the link you posted earlier?
The low beam is yellow or blue in a stock 7?
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 12:58 PM   #55
mbworldz
Drives: 2011 535i
Ya that link I post earlier.
The stock one low beam is below 5000K So it looks little yellow to me.
      09-26-2010, 01:00 PM   #56
SAMLAMBO
Ok thanks for all your help. I will change the angel eyes from yellow to the bluish white. Just to confirm, the wattage and all is the same correct? Dont want any problems.
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 01:04 PM   #57
mbworldz
Drives: 2011 535i
It really depends on your car. It will not cause electrical problem.
The bulb will work but it might show the error code on your dash thats it.
That bulb has the correct voltage. Don't worry your car will not blow up lol.
      09-26-2010, 09:53 PM   #58
SAMLAMBO
i realised this morning that there are two rings on each head lamp so would I not need two pairs? One ring is smalle than the other.
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 09:54 PM   #59
mbworldz
Drives: 2011 535i
You only need one pair. A box comes with 2 bulbs. Confirm with seller just to be safe.
      09-26-2010, 09:58 PM   #60
SAMLAMBO
2 bulbs for 2 rings but altogether there are 4 rings, each headlamp has 2 rings correct?
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 10:06 PM   #61
mbworldz
Drives: 2011 535i
No no no........
Each side has 2 rings, but you only need one bulb for each side.
You only need one bulb to run two rings on each side.
Check out this details post, it has pictures on how to change it.
http://www.bimmerfest.com/forums/sho...d.php?t=415604
      09-26-2010, 10:11 PM   #62
SAMLAMBO
No no no........
Silly me!
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 10:13 PM   #63
mbworldz
Drives: 2011 535i
By the way can you try locate this whiteline tail lights for us if you are in Singapore.
http://www.7post.com/forums/showthread.php?t=435033
Silly me!
      09-26-2010, 10:21 PM   #64
SAMLAMBO
Let me ask but you sure, there is no contrast with these lights.
2012 BMW 740i
2011 Mercedes E250
      09-26-2010, 10:55 PM   #65
7erMOB
7erMOB's Avatar
Drives: F02 740LI
mbworldz: Love the color on ur AE, they are very nice. I know its hard to capture the true color in camera, but in person the AE should be less blueish right?
I saw these lights in HK on sale, but was hesitating to installed them.
1. Heat is really bad in HK, summer 36+ on the road with buses and other cars on the road. The heat housing IMO is not good enough compare to like MTECH LED lights (aluminum housing) for 3 series E90 model. Heard others that this model melted in the angel eye socket area.
2. Others have had error codes as well after 2 months, keep us posted on error codes if any. Hopefully you won't have any.
Our 7er uses the same H8 AE bulb as E92, there are tons of info in the 3er section. Others should look into those forums to see which solution is best for their own needs.
PS: Wondering if E92 lighting has any input
Drive Fast or Don't Drive!!
      09-27-2010, 02:33 AM   #66
SAMLAMBO
Now I am confused to buy or not
2012 BMW 740i
2011 Mercedes E250
