05-08-2019, 06:06 PM | #89 |
Rep 231
Mine arrived today! Still not sure if I'm going to try to tackle this myself or not. The sucker is heavier than I expected at ~70lbs. But I've manhandled 5 speed trans into and out of place on my back many times, but damn those were not fun days.
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3’s | Vorshlag Camber Plates |
05-08-2019, 06:15 PM | #90 |
Rep 417
05-08-2019, 11:14 PM | #91 | ||
Rep 10,473
Furthermore, they are dropping 50% of their drivetrains. There will be no new revised 3.15 M Performance LSD. |
jimmy8904563.00 |
05-09-2019, 07:41 PM | #92 | |
Rep 553
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
05-09-2019, 08:28 PM | #93 |
Rep 1,934
So did any xdrive users make the purchase?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
05-09-2019, 08:41 PM | #94 |
Rep 2,963
Yeah so I have literally zero self control and ordered one for my 2015 335RWD Manual. I'll let you guys know!
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
neonnblack139.00 |
05-09-2019, 10:02 PM | #95 |
Rep 191
I ordered one for my 435i xdrive from my local dealer (price matched ecs). They confirmed will fit on xdrive. shop.bmw.ca also confirms this. See attached
05-09-2019, 11:42 PM | #96 |
Rep 2,435
Drives: 2021 M2C
05-09-2019, 11:44 PM | #97 |
Rep 191
I'm not 100% sure if it'll fit on a 440i but that's what bmw Canada says online. I'd double check. However will definitely fit up on xdrive according to my local dealer. I can confirm within a week once mine arrives
05-09-2019, 11:52 PM | #98 | |
Rep 10,473
There were actually 2016 and 2017 F32 440i that were PRE-LCI and used the 3.15 rear ends with the B58 engine. That's not the case with the F30 PRE-LCI. As I explained in the beginning, it all comes down to cars that have 3.15 rear ends. The F32 LCI with the 2.81 rear ends (2017 - there were no 2016 LCI 440i) are not compatible. |
05-11-2019, 06:02 PM | #99 | |
Luxury at the redline :)
9108
Rep 7,563
Good luck with all that.. |
05-11-2019, 06:05 PM | #100 | ||
Rep 191
upsidedownfunnel2004.50 |
05-11-2019, 06:18 PM | #101 | |||
9108
Rep 7,563
Well, if works for a factory-installed Audi, then it must work for another random manufacture.... Your x-drive is automatic, correct? Read between the lines: https://www.bimmerpost.com/forums/sh...php?p=24374008 Just because it's listed on some random parts catalogs, doesn't mean it's accurate. They cross-reference parts of other models all the time. Good luck but I bet you gazillion, kajillion dollars it won't work properly. |
05-11-2019, 06:26 PM | #102 | ||||
Rep 191
I respectfully disagree that this won't work on my automatic xdrive 435i. I will get the dealer to install as they confirmed this "random parts catalogue"(bmw Canada's own site) is correct. They will be responsible if this doesn't work out but they assured me it would. Ratio is same as oem unit too so not the wrong part. I'll report back either way... |
05-11-2019, 06:41 PM | #103 | |||||
9108
Rep 7,563
Yes, an LSD can possible work with an an AWD, like the Audi and F90 M5, however, they have a difference computer-controlled, torque-vectoring set up, so the vehicle can intelligently manage a rear split of power. The mechanical system offered for the 3 series is not electronic, so it doesn't sync with the vehicles's DSC and brake-based e-diff. The MP LSDs are made specifically for each vehicle's pre-populated configuration. X-drive not included. You already mentioned the dealer is unaware of this, so when the axels doesn't fit or your vehicle starts throwing generic drivetrain malfunction codes, you can pass the buck on to them, like with this guy: https://www.bimmerpost.com/forums/sh...php?p=24465410 [U]AWD[/U] vehicles with electronically-controlled torque-vectoring LSDs: |
05-12-2019, 07:50 PM | #104 | ||||||
Rep 10,473
The link you posted states the LSD will not work with a 340i. As stated multiple times in this thread, it works with the 3.15 rear ends. The 340i rear ends are 2.81. That's why it doesn't work. Instead of calling BMW websites (and realoem among others) "random websites" that are wrong, you should stop posting "random posts" that do nothing to support your claim that these do not work with AWD Xdrives. Last edited by IK6SPEED; 05-12-2019 at 07:57 PM.. |
jimmy8904563.00 quikM2372.00 |
05-12-2019, 07:56 PM | #105 | |||||||
9108
Rep 7,563
When folks start installing it in mismatched vehicles and their dashboard light up like a Christmas tree.. It they care to admit it. I'll be back.. In the meantime, go take your chill pills, bro it's not that serious.. |
05-12-2019, 07:58 PM | #106 |
Rep 2,963
Just because the gear ratios are different doesn't mean it won't work. I put a 3.64 rear end on my 3.23 E90 330 and it worked fine just had higher rpm in all gears
05-12-2019, 08:00 PM | #107 | ||
Rep 10,473
It WILL work on a 2016-2017 PreLCI F32 440i. It WILL NOT work properly on any F32 440iXDrive. |
jimmy8904563.00 upsidedownfunnel2004.50 |
05-12-2019, 08:11 PM | #108 | |
9108
Rep 7,563
I'll wait.. |
05-12-2019, 08:13 PM | #109 | ||
Rep 10,473
You that sure of yourself? Going to enjoy your M2 ! |
