      08-26-2018, 12:02 PM   #133
EliaZinn
Drives: 2014 BMW M6
Originally Posted by Almaretto View Post
DO you have access to BDC_Body in Bimmercode? Code is there.
Unfortunately I do not- see a screenshot of all my options (unless its in expert mode).
Also trying to find a way to code the BMW Ambient Air to turn on automatically with the can- anyone know?
Thanks..
      08-26-2018, 12:37 PM   #134
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Thanks..
May not be supported yet, unless it is in expert mode.
      09-17-2018, 02:47 AM   #135
turas
turas's Avatar
63
Drives: 440ix
I've use Bimmercode and it's week in "standard" mode. It's looks better in expert mode but it's hard to know what do you want to change.
I want to change:
- seat belts reminder remove
- change start up logo in rear entertaiment system
- start/stop turn off
- change "drive mode" from default to last choice
I'll be grateful for helping me where i can find it in expert mode.
      09-27-2018, 11:24 PM   #136
keithbui86
Drives: bmw g12
Hi,
my g12 come with Harman Kardon sound system. I retrofit it to Bower wilkin system.
Done all the wiring right.
Just find out the B&W system require bigger power cable for the amp.
Change the power cable.
Suddenly the sound is bigger but bad. No more define and control, middle sound flat, tweet lose it crisp sound it used to has.
What could be a problem? is it possible that the amplifier has reset when i discharge it? Do i need to recoding all the way again?
Feeling really bad.
Please help and pardon my english.
Best regards.
      09-27-2018, 11:26 PM   #137
Almaretto
Almaretto's Avatar
2376
Originally Posted by keithbui86 View Post
Hi,
Feeling really bad.
Best regards.
Did you VO code?
      11-26-2018, 11:41 PM   #138
BMW Thailand
Drives: 2010 BMW F02 730Ld
Has anyone retrofitted/coded up LED headlights, yet?
I have just done the retrofit and the result after coding is that all lights are coming up one-by-one for only few seconds then after everything goes off.
It is an obvious error code but I can't figure what is wrong.
Did a new custom wiring and replaced both FRM (61 35 6 992 947) and ZGW (61 35 9 322 532)
All modules are brand new.
Any ideas would be greatly appreciated.
BR, Thank you.
      12-13-2018, 07:24 AM   #139
iyad.nasser
iyad.nasser's Avatar
Drives: bmw
Originally Posted by CaboM4 View Post
I am using TokenMaster's Launcher PRO 2.5.5 Build 120
There are no cheat codes found for CAFD_00002098
Did you modify your FDLCodes.xml file? Can you share which 2 lines you are modifying?
what program is that ?
      12-13-2018, 09:44 PM   #140
Almaretto
Almaretto's Avatar
2376
https://www.bimmerfest.com/forums/sh...d.php?t=983244
      12-27-2018, 08:03 AM   #141
Wills2
Barge driver
Wills2's Avatar
Ukraine
8716
Drives: 730d
Has anyone coded the Alpina blue instruments on their 7 yet? Bimmercode says it's available but I wonder if the diesel dials are there or just the petrol. (rev counter)
730d/Z4C
      01-04-2019, 11:37 AM   #142
turas
turas's Avatar
63
Drives: 440ix
It works on diesel.
Wills28716.00
      01-04-2019, 01:41 PM   #143
Wills2
Barge driver
Wills2's Avatar
Ukraine
8716
Drives: 730d
Originally Posted by turas View Post
It works on diesel.
Thanks Turas.
730d/Z4C
      02-05-2019, 12:57 PM   #144
turas
turas's Avatar
63
Drives: 440ix
Where to find option to change to Rolls Royce sound gongs in bimmercode?
      02-06-2019, 12:20 AM   #145
Almaretto
Almaretto's Avatar
2376
Expert Mode > HU_NBT2
      02-06-2019, 03:35 PM   #146
M6BMWDriver
M6BMWDriver's Avatar
Drives: F12 Singapore Gray M6 Conv
Hi There,
I have a 2018 G12, not able to remove the seat belt reminder. The cheat code did did not see the codes in the ncd file. Any idea where i can find it?
      02-07-2019, 07:20 AM   #147
turas
turas's Avatar
63
Drives: 440ix
Thank You. Is it possible to change sensitivity of mirrors anti-dazzle function via bimmercode?
      02-07-2019, 09:28 PM   #148
M6BMWDriver
Originally Posted by M6BMWDriver View Post
Hi There,
Dear All,
I found a way to deactivate the Seat Belt reminder in a 2018 G12 750
the warning is based on the speed of the car, and there is no way to just turn it off, so you have to override the Wrete to FF
HERE is HOW
edit FDL CAF [ACSM_5]
under 3001 Gurtwarnung, 32
SBR variant (Not sure what this is)
SBR (Seat Belt) disabled without SBE (long-term); SbrVariantDriv set to SBR_ohne_SBE_SBR-3.0 SbrVariantPas set to SBR_ohne_SBE_SBR-3.0
Deactivation belt condition indicator driver in cluster SbrDispBltStDrivEnb Set to NICHT_¬AKTIV
Deactivation belt condition indicator front passenger in cluster SbrDispBltStPasEnb Set to NICHT_¬AKTIV
Speed threshold for motion detectionSbrVvehMotion Wrete = FF
Speed threshold for SBR (Seat Belt) warningSbrVvehWarn Wrete = FF
Speed threshold Cancellation of Drive warning to FFSbrVvehWarnCnclDriv Wrete = FF
I hope that will help.
      02-08-2019, 09:05 AM   #149
Martin2C
Drives: 2017 750i M Sport
I must be missing something, why would you want/need to turn off the seat belt reminder?
      02-08-2019, 05:08 PM   #150
M6BMWDriver
Because it’s annoying
And when you get stuck in a car and you can’t get out in an accident, like it happened to me and the fire department had to cut it off, you think i want to wear that thing anymore!!!
      02-10-2019, 10:59 AM   #151
Wills2
Barge driver
Wills2's Avatar
Ukraine
8716
Drives: 730d
Yes, that way there is still something worth cutting out.
730d/Z4C
      02-17-2019, 05:16 PM   #152
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
I got one. For all you G series owners with drivers assistance. Wouldn't it be nice to extend or remove all together the automated steering cancellation when you take your hands off the wheel for an extended period of time?
Not sure if I explained it clear. With steering assist enabled, taking your hands off the wheel for 7-10 seconds and the features disables. Would love to disable that.
      02-17-2019, 05:27 PM   #153
Wills2
Barge driver
Wills2's Avatar
Ukraine
8716
Drives: 730d
I like to have my hands on the wheel but I'm old fashioned that way, it disables because the car isn't capable of driving itself.
730d/Z4C
      02-17-2019, 05:30 PM   #154
markymarc1979
2009 BMW E93  [0.00]
I understand the safety aspect of it, but it disengages too quickly.
If theres an option to extend or disable all together, I'm definitely coding it.
