11-20-2021, 09:12 PM | #177 |
Rep 764
Drives: 2019 BMW X6M
I certainly expect he will, whether Ham wins the WDC or not.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
///M Power-Belgium64716.00 |
11-20-2021, 09:52 PM | #178 |
Rep 4,445
The Merc was planted, Hammy required significantly less steering movement to keep pace through the twisties. Car was dialed in.
Almost as if hammy took Bottas set up and detuned Bottas. Max’s swap to a higher downforce wing due to DRS failure unbalanced the car. Amazing what he could get done with the setup on a new track. Merc is always good sending out cars for qualifying, RBR tends to get themselves in traffic. Perez can’t figure out how not to get passed on his warm up lap. Merc will be tough to beat, but it only takes one wide run in a low rake car over the curbs to change the outcome. AT must make their front wings out of cardboard and packing tape, Gasly loses the front wing all too often.
F87source7367.00 Blindside_1376755.00 |
11-20-2021, 09:58 PM | #179 |
Rep 764
Definitely excited for this track and race.
The start to the first corner is going to be critical for the top 5 for sure. Ham, Max, and BOT on mediums and Gasly and ALO on softs.
2019 BMW X6M
11-20-2021, 10:13 PM | #180 | |
Rep 7,542
I still don't think Alonso even on softs will be a threat to the top 3, because straight line speeds of the Honda and Merc pu will be quite high and likely the renault engine won't be able to keep up. Then in the corners with that much traffic and dirty air the following cars even with the soft tire likely won't be able to do much. In terms of Gasly the same applies except he might have more straight line speed.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
Autobacs1397.50 |
11-21-2021, 12:36 AM | #181 | |
#buildnotbought
11123
Rep 4,930
afaik Max still has to go to the stewards. Allegedly double yellow was waved but nothing showed up on his onboard monitor nor on the central computer system (so his team could warn him for the double yellow). Strange situation; if that's really the case something is very wrong with the FIA warning system.
M5Rick61854.00 Blindside_1376755.00 |
11-21-2021, 01:16 AM | #182 | |
Rep 7,542
1) Redbull and the FIA were in on it, the FIA told redbull not to have any indash warnings or radio warnings to max on yellow flags so he doesn't have to slow down. Then when they get caught the FIA will let him go and blame it on system issues. #MAXFIA. 2) Rebull were cheating by purposefully eliminating any warning systems on their cars or pitwall, this way they could potentially have another few tenths of full speed before max pyscially sees the waving flags. Then when caught they would make an excuse for the FIA's system being glitchy and say neither of their systems worked therefore it must be a mistake and hope for a warning because atleast max stopped at the second he saw the flags. 3) Insert any dumb excuse here.
11-21-2021, 02:15 AM | #183 |
Rep 19,974
11-21-2021, 02:23 AM | #184 |
Rep 19,974
11-21-2021, 02:27 AM | #185 | |
Rep 19,974
11-21-2021, 02:30 AM | #186 |
Rep 19,974
11-21-2021, 04:14 AM | #187 | |
Rep 7,542
However you guys literally stalk mercedes's every move and update, and actually post conspiratorial comments about them like your lives depended on it - literally as it happens. Like I said before projection. It helps to be self reflective.
minn1914078.00 |
11-21-2021, 05:37 AM | #188 |
Rep 19,974
''We have pictures of the rear wing from Budapest onwards'' Protest is almost imminent.
https://www.planetf1.com/news/christ...es-score-mark/ |
11-21-2021, 06:41 AM | #189 |
Rep 1,831
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Grid penalties...5 spots for Verstappen, 3 spots for Bottas.
11-21-2021, 06:48 AM | #191 | |
Rep 1,972
Whilst sympathetic to that, “Article 27.1 of the Formula 1 Sporting Regulation states that the driver must drive the car alone and unaided.” |
minn1914078.00 |
11-21-2021, 06:56 AM | #192 |
#buildnotbought
11123
Rep 4,930
So a good lesson not to fully trust on the onboard monitor.
I wonder if there will be a tyre change for Max or BOT now that they're further down the grid; maybe start on softs? To get that extra jump at the start.
11-21-2021, 07:00 AM | #193 |
Rep 1,831
Drives: E86 3.0si
Nope...."For drivers who qualify for the race in dry tires, they must start the race with the tires used in the second session of qualifying. This applies for the Top 10 drivers from the qualifying sessions. For drivers that qualify outside the Top 10, he can start the race on tires available to them – soft, medium or hard"
11-21-2021, 07:04 AM | #194 | ||
Rep 24,950
BUT !!! The latest (just in) I'm just reading that MAX got a 5 P penalty . Too bad => https://nl.motorsport.com/f1/news/ma...qatar/6805480/ This means MAX is P 7 ...And he can lose the WDC by the whole situation .. Yesterday the Merc preachers said : It's the MaxFIA ?!?! It's such a BS as usual...
M5Rick61854.00 |
11-21-2021, 07:11 AM | #195 | |
Rep 24,950
Really mate ??? Once again your statement is BS !
M5Rick61854.00 |
11-21-2021, 07:12 AM | #196 |
Rep 19,974
11-21-2021, 07:14 AM | #197 |
but no flokka
523
Rep 717
It's literally the first thing you learn… always keep an eye on the marshal stations. Sounds like all the driver (not just max) have gotten too comfortable relying on the tech in their cars.
minn1914078.00 FuzzyPeaches490.50 |
11-21-2021, 07:15 AM | #198 | |
Rep 19,974
