08-28-2010, 07:03 PM | #1 |
Rep 5,012
F1 technical question
Hey gang, I'm curious how the 'manual' clutch is operated for launches, and where it physically is. I know it's some kind of lever near the steering column, but that's all. Since it's an electrohydraulic clutch, I doubt the lever is directly connected to the clutch, like on our 6MTs. I'm betting the lever is more like a rheostat than a true clutch, but at least it's not fully automated (launch control). Pics would be great . Searched for that but zero bites; only the typical technical specs most of us already know. Thanks gang.
08-28-2010, 11:16 PM | #2 |
Rep 3,288
Basicly, right behind the steering wheel where the paddles are for the shifts, there is a 2nd set of paddles, 1 on each side, for the clutch. All 4 paddles together make kind of a butterfly shape.
Both clutch paddles work, and the reason there are 2 is because the drivers will press 1 partially the way down and hold it, and then use the other one to fully press down to make the actual change. After the change has been made the fully depressed clutch paddle is released and the partially depressed paddle is slowly released to allow for a consistently smooth shift. I'll try to find a picture and illustrate it.
08-28-2010, 11:23 PM | #3 |
Rep 3,288
Here is a picture I marked.
I know McLaren's wheel actually has a 3rd set of paddles. I'm not exactly sure what they are for. But this is the general purpose of how it works.
08-29-2010, 12:48 AM | #4 |
Rep 5,012
Thanks a lot man. I'm still a bit confused how the clutch paddles work, since they're only needed for 1st and from a standstill, right? You mentioned 'for smooth shifts', but all drivers seem to do while underway is just touch the up/down shift paddles. So just like I suspected, the clutch paddles are just like a rheostat, but I don't quite get if each paddle has a different purpose, or they're redundant.
Oh, and have another question: Do F1 cars have a semi-launch control, where the driver can just mash the throttle and the car holds the revs at an adjustable rpm until clutch is released? Hope the answer is no . Thanks again for your help; at least I learned where the paddles are . Looking forward to the race tomorrow. |
08-29-2010, 01:11 AM | #5 |
Rep 1,190
What exactly do those clutch paddles do? Do those disengage the clutch?
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
08-29-2010, 01:46 AM | #6 |
Supreme Allied Commander
1971
Rep 61,781
Drives: A BBS WHORE
I forgot the exact sequences and what did Martin Brundle said during BBC's pre-race show.
He said something during the formation lap, the driver had to do a certain burnouts to get the bite point right. Then use the clutch peddles at the bottom rear to set the bite points or something. Release the right one when you build up the rev when the five red light sequence starts (the car will bog a bit if i remember what i heard)...and release the left when the light turns off....then shift up going down the straight....
08-29-2010, 01:54 AM | #7 |
1971
Rep 61,781
Drives: A BBS WHORE
Speaking of Clutch...
09-02-2010, 05:15 PM | #8 |
Rep 5,012
Don't worry man; thanks anyway. Hopefully a vid will show up sometime. I've seen F1 cars reverse slowly, but I bet electronics (like a DCT) is doing the work there, rather than the paddles. Take care.
09-02-2010, 10:44 PM | #9 | |
Rep 3,288
Also, I don't believe there is any launch control on F1 cars. They only have an anti-stall system. Which is why they can still bog off the line.
09-02-2010, 11:44 PM | #10 | |
1971
Rep 61,781
Drives: A BBS WHORE
09-03-2010, 06:48 PM | #11 |
Rep 5,012
It's illegal, that's for sure . 'Anti-stall' is still a launch control aid IMO, but at least they have to manually operate the electrohydraulic clutch to start (makes the race more interesting). And F1 regulations only require physical clutch actuation from a standing start. Look at the hands of drivers from the on-board rear cameras while racing and most just tap the paddle with ONE index finger (depending if up or downshifting). My curiosity is how the paddles are operated for the starts. Have a good one.
09-06-2010, 01:08 AM | #12 | |
Moderator
675
Rep 4,737
The clutch pedals are probably only used when stopping completely or accelerating from a standstill, i.e. pitting, or when you spin out |
09-06-2010, 02:34 PM | #13 | |
Rep 85
And for gettin out in pitlane. |
