07-14-2017, 12:11 PM | #1 |
sportscars only
3244
Rep 3,195
windshield chips repair
I'm getting a couple of lousy smallish cracks, any suggestions for good DIY kits that actually work and makes them disappear? TIA.
07-14-2017, 12:16 PM | #2 |
Rep 9,160
If you have glass coverage in your insurance, this should be free. Unless you just want to learn to do it yourself, call your insurance and let Safelite do it.
07-14-2017, 01:34 PM | #3 |
Rep 5,577
did the cracks emanate from a chip or are they really just chips?
http://www.popularmechanics.com/cars...shield-repair/ Griot's Garage used to sell a chip repair kit but looks like they stopped. |
07-14-2017, 01:54 PM | #5 |
Rep 5,577
if a rock hits the windshield and creates a crater depending on size you can fill the crater rather easily, buff and possibly make a hard to detect repair.
if a rock hits the windshield and creates a starburst; chip with veins emanating from it, then if the entire defect is smaller then a quarter good chance a repair may prevent the crack increasing but probably won't make the defect disappear. The worst scenario is if you get a rock hit that creates a chip or a starburst but instead of that initial damage staying stable the impact starts to spread then you need to repair as soon as possible and then you need to inspect to find out if the repair holds and be prepared for possible window replacement if it does spread. |
07-14-2017, 02:02 PM | #6 |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
We got the permatex windshield repair kit on three different occasions through Jeff Bezos' website. Works well but you have to be patient, make sure you properly fill the crack and then make sure it cures long enough so you don't end up pulling the resin back out. At first, it took a few tries to get it right, but they are typically less than $15. You can do a number of chips with one kit if you do it right.
tranquility3243.50 |
07-14-2017, 02:07 PM | #7 |
sportscars only
3244
Rep 3,195
Tx, I'll check out that kit. I have those small crater ones that won't spread but still looks nasty. No veins, it's all contained in a circle pattern.
07-14-2017, 05:50 PM | #8 | |
Rep 3,470
The purpose of the repair isn't to make it invisible, it's to stop your windshield from cracking. Even when the pros do it, it doesn't just "go away". Sometimes it'll be nearly invisible when they are done, sometimes not. |
Red Bread4463.00 |
07-14-2017, 07:13 PM | #11 |
Rep 3,470
07-14-2017, 11:30 PM | #12 |
sportscars only
3244
Rep 3,195
07-15-2017, 01:25 AM | #13 | |
Rep 3,470
We are somewhat "experts" when it comes to this up in Alaska, because they put freaking rocks on the road for traction for all the dip****s that refuse to get studded tires in the winter. So of course these go flying everywhere, especially before the big "clean up" in the spring where they run the street sweepers down the highway and collect all the crap, so they can use it again. We get peppered with all sorts of hits. By fixing the chips, you significantly increase the life of your windshield. Here, you pretty much have to do it every year, but if you get lucky and are on top of it, you can stretch that out some. I got 2 years out of my current one. "Fixing" doesn't mean you can't see the chips after you fix them, it just means you've applied the resin correctly, scraped the excess, and prevented the chip from propagating. So I'm not sure what you mean by "fixing" it, if you mean replacing the entire thing or fixing a few cracks. Both will "fix" it, if the cracks are mall enough and not located on an edge, but only one will look "totally perfect" obviously. We take so many hits here that I don't give a crap if it's OEM glass or not, as long as it's the right thickness (OEM specs) it's fine, because really, nothing is going to hold up over the long run. Far more important to fix the little chips when they occur.
07-15-2017, 01:50 AM | #14 |
sportscars only
3244
Rep 3,195
Ya, like I said, I'm 'fixing' it just for aesthetics, nothing else. There are very minute chips that haven't grown at all. The structure is still sound *knock wood*.
07-15-2017, 03:20 AM | #15 |
Rep 2,062
I bought a RainX repair kit at Wal-Mart for like $11 and have repaired like 10 chips on 4 different cars. The key is using a heat gun inside the car so that capillary action will suck the glue into the window, then pull it outside into direct sunlight since the glue cures via UV rays. Works great and just as good as any tent style rock chip guy in a parking lot and no need to call insurance to add claims to your policy.
07-16-2017, 01:33 PM | #16 |
Rep 333
