03-24-2018, 02:01 AM | #111 | |
Rep 39
I honestly was trying to educate you. You definitely got away a lot more from our conversation than I did (I hope you learned a few things, because I didn't really). The only things I was offended at was some points you made that are completely unfounded. MRIs are not considered dangerous and asking me to get an MRI for an hour everyday isn't a personal attack to show me that it's harmful isn't it? Not all radiation is bad (Vitamin D synthesis, some of it promotes healing and skin formation, radiation therapy actually helps people, some radiation is harmless such as visible light....). Everyone knows that smoking is dangerous. There's scientific proof. Open up a smoker's lung. There's no evidence that MRIs are harmful. Again, I hope you learned a few things. That's all life is about. The pursuit of knowledge. I agree to disagree as well. |
03-24-2018, 08:14 AM | #112 | ||||
Rep 3,456
Drives: Harrop E90 M3
Maybe you can comment on the electric car history all time, rather than modern times. Electric cars were made nearly a century ago. Internal combustion engines were quite inefficient and almost never made it. Politics dictates a lot of things and the big oil companies had more funding than their competitors, which were mainly electric and steam engines. |
03-24-2018, 08:31 AM | #113 | |||||
Rep 9,134
But you probably still don't get it. |
03-24-2018, 08:55 AM | #114 | ||
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
03-24-2018, 11:23 AM | #115 | |
788
Rep 3,972
I have achieved 148 miles on my BEV from Oxnard to Gaviota and back and some in town driving on a 97% charge (117 mi rating). This was a remarkable 165mpge, although it was a test done in eco pro+, 57 mph when I first got the car. Driving on the freeway, 70-80mph and hitting normal traffic in between still yields over 100 miles. I can slow to 75mph, and then still cruise 94 mph up the Conejo Grade. Went from Bakersfield to Oxnard, 110 miles and averaged 140mpge efficiency, cruise control set at 65 mph up the Grapevine. ( 75mph on the way there). The car is remarkable, so fun to drive, easy to park, and solidly built.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
03-24-2018, 02:34 PM | #117 | ||
Rep 1,003
03-24-2018, 03:22 PM | #118 | ||
Rep 2,350
Same as EMF versus MRI. My small battery bothers me but doesn't bother me. - A 12V small battery that is used just to start the vehicle can not be compared with a huge battery that you sit on. Are you kidding? - Firstly they are very different in terms of composition and secondly, even if they were the same, the emissions between the two are kind of like a cigarette passive smoke versus fire smoke. Not even. - The starter battery is not used to run an electric engine -> no field - A bigger pack of batteries for Ev needs a special design. Please look at the first Electric vehicles or hybrid and you might see the vent openings and the fans mounted for ventilation. The new vehicles design conceive everything from your eyesight - Anyway, ideal is that the battery is placed in an open space (engine bay) but BMW and some other manufacturers placed the starter battery in the trunk just to achieve the 50-50 weight ratio that improves the chassis, recte the improved balance and handling. Like Citroen used to put the spare tire on left and battery on the right. - there is not big of a concern for a small starter battery if is place in the cabin space (trunk), however, you can always replace it with a dry one. - no need Google, just read on the battery label that tells you a lot about content, warnings and charging requirements. Now keep in mind that batteries get a charge while driving. Tesla battery Pack System "A thermal management system is provided that minimizes the effects of thermal runaway within a battery pack. The system is comprised of a sealed battery pack enclosure configured to hold a plurality of batteries, where the battery pack enclosure is divided into a plurality of sealed battery pack compartments. The system also includes a plurality of battery venting assemblies, where at least one battery venting assembly is integrated into each of the sealed battery pack compartments, and where each of the battery venting assemblies includes an exhaust port integrated into an outer wall of the battery pack compartment and a valve, the valve being configured to seal the exhaust port under normal operating conditions and to unseal the exhaust port when at least one of the batteries within the battery pack compartment enters into thermal runaway." "The main object is to provide a high-reliability battery pack that is capable of exhausting the gas even when the quantity of the gas released from the cell is small, and to provide a vehicle with the battery pack which can improve the reliability. A battery pack has a battery module unit that is formed from a plurality of arranged battery modules, each of which has a plurality of cells in a case, a cooling air flow passage where a cooling air flow flows, and a gas exhaust duct which forms a gas exhaust passage. The gas exhaust duct extends in an arrangement direction of the plurality of the battery modules while being contiguous to the battery module unit, and takes in the gas released in the case from the cell, then exhausts the gas from the battery module. The gas exhaust duct is provided with a gas inlet for taking in the gas, which communicates with a gas emission hole formed on a surface of the case, and an air intake that serves to take in the cooling air flow." Now, are you sure you are comparing my starter battery with a whole EV pack? Anyway, you deviated again from EMF which is A WHOLE OTHER ISSUE, but I went along to give you some information. My initial point was that leaving aside the toxicity and other issues, you are sitting all that period on the top of an EMF field. As a side note, I have an academic education in the field. What you as a user know (or they want you to know) is different than what you know or need to know as an engineer behind the scenes. You might like the hot dogs; but the guy who makes them never eats them. And to answer to your question, engineers and technicians that work in these fields are included in a special work hazard niche. Guess why? In Europe, these occupations are categorized under a special occupational hazard category and they receive a supplementary payment in salary and pension plans for that. In some European countries, there are also certain rules that forbid to be in the field more than a certain period of time. Again, do you know why? Please compare your north American 'in parameters" "safe" standards with the European ones and ask yourself after why in Europe the regulated accepted levels are in some areas even a thousand times less. Quote:
No thank you, I got my education in a perfect academic environment, where we learn things as they are. My point was that nothing in excess is good; is one thing to have a small battery that is used solely to start a vehicle and that's it, and is a different thing to sit on a huge chemical plant that drives four motors that also produce fields. Cell phone is harmless too (not really) but using it non-stop or living by a cell tower is a different story. But some are ok; their choice. Again, your comments are all over the place and nobody asked you anything about the good radiation. What are you trying to prove with this common knowledge? All natural processes like vitamin D synthesis, are harmless because this is the environment our body has been conceived in and developed since the beginning. It is natural, we developed end evolved in time based on our environment. There are species that can thrive in every environment. Anyway, you are always deviating all over the place, from EMF, to MRI, to high current and to power plants, plus you have a very hypocritical way of addressing your perception while adopting a condescending attitude towards the other and for this reason I will do my best to avoid you in the future. |
03-24-2018, 04:19 PM | #119 | |
Rep 4,210
So...yes...the real mileage will likely be less but still more than adequate. |
03-24-2018, 06:45 PM | #120 |
Rep 2,923
Bye bye Tesla
Currently: '24 Mercedes G63 | '24 Porsche GT3 RS | '24 Volkswagen GTI
Previous BMWs: 340i, 740i, 745Li, M3, M4 Previous Others: Audi, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen |
Brake_Late1936.50 |
03-24-2018, 10:20 PM | #121 | |
Rep 39
Tesla enthusiasts also concerned about EMF has multiple threads about the issue and many even took readings while the car is parked and during WOT. The result? No difference from conventional cars. WOT in a Tesla resulted in 800nT reading whereas a BMW 5 series resulted even more at 7000nT. How is this possible? Faraday cage effect? Tesla shields from EMF? Basically microwaves, LCD screens and other daily things produce EMF on par with those levels, so the readings they measured mainly result from EMF generated within the cabin itself. Maybe BMW has more electrical components inside compared to a sparse Tesal interior. Read the links. Pretty interesting stuff. https://teslamotorsclub.com/tmc/thre...model-s.28494/ https://teslamotorsclub.com/tmc/thre...adiation.2335/ Here a discussion where the Earth's magnetic field is greater than EMF exhibited by Teslas: https://forums.tesla.com/forum/forums/emf-dangers If you have any data on measurements of EMF in EVs, please share. The science community recognizes that low frequency EMF is harmless. In this case, EMF radiation can be looked at like visible light radiation (in terms safety). EVs do not produce high frequency EMF like mircowave ovens (which can be analogous to gamma radiation in my "light" analogy), they only produce low frequency EF. If you have documented results that prove otherwise please share, because it seems like the European safety standards are there without any evidence (or maybe they are protecting against HF EMF and just decided it's easier to blanket the whole spectrum and put a universal limit because it'd be too complicated to understand). I also still don't understand why you think MRIs don't apply here. They are an extreme example of EMF. In fact lots of studies that focus on trying to prove that EMFs are harmful utilize MRIs (they call conclude that there is no measurable damage done btw). Look them up. You can vary the frequency and magnitude of EMF all over the place with those machines. Cars produce EMF in levels of nano Teslas whereas MRIs range from 1.5 - 3T or above (that's a million to a billion times more) a field so powerful that it reorients the water molecules in your body. I can't really think of another situation where EMF exposure is so high. If EMF exposure is harmful, surely MRI patients will show signs of disease first (which has never been documented to my knowledge) as sitting in a MRI machine for an hour which is a very routine length of procedure would equate to a billion hours (114,000 years) in a EV. I'm curious to know what the European safety standards for MRI patients are and the evidence they used to back that up? EMF, current, MRI machines are all related. High current equals EMF. Alternating current = EMF. MRI exhibits high current. Power plants exhibit high current. EV's produce less current, that's why I brought all those extreme situations to bear. I don't understand why you think those examples don't belong in this argument, feel free to explain in specific detail why not. From my understanding Li-ion batteries need venting in case of "thermal runaway" where the battery fails. They do not release gases under normal operating conditions. They are in sealed enclosures with a vent check valve that is normally never used. If you get in an accident where the battery is damaged or bursts into flame, then yeah, the batteries short, undergo thermal runaway and there must be a venting system in place to prevent a catastrophic explosion and therefore release fumes that if you breathe are dangerous. But the same applies to ICE, which happens whenever you use the car. So from my reading.... Tesla has less EMF exposure and less poisonous fumes to breathe in... EDIT: Although I find this conversation pretty educational now that I've begun to research this EMF scare topic (interesting fact: the Earth's natural magnetic field is on several orders of magnitude greater than what an EV emits), my personal opinion on how toxic EV batteries are for your daily driving health is that they are minimal (as previously mentioned dry Li-ion batteries - the current power source of modern EVs - don't normally vent). Hypothetically, what if a salesman trying to sell EVs said to you (a potential car buyer) that EVs emitted a gas that was toxic for you to breathe in during normal operation... So toxic in fact that if you sealed yourself in a room with the car running, you'd die of the poison in mere minutes. But no worries! Just don't let the battery run in closed environments and you'll be safe! Would you buy the EV?... It's funny because ICE (which no one is afraid of) have this property. Lots of people have died from the fumes that are emitted from ICE drive train emissions and NO ONE has died (or let alone even had documented disease) from electric motor EMF. That's how toxic ICE drive trains are. Pushing out poison continuously. And people are concerned about EMF (measured as the same with ICE cars anyways) and Li-ion fumes (which normally are never present)? So from my perspective EMF and "ventilating batteries" are extremely weak (if not non-existent as explained above) arguments against EVs as ICE represents a much greater potential danger to health. It seems that you're so focused on looking at the cons of EVs that you forgot to look at the bigger picture. Last edited by Bavariane31; 03-25-2018 at 03:49 AM.. |
03-25-2018, 05:17 AM | #122 |
Rep 1,483
Just to wade in regardless of the EMF exposure, the particulate matter created by brakes and tyre wear is still a massive air pollution problem, and only set to be exacerbated by having heavier cars which electric will undoubtedly be.
(My road designing civil engineer friend explained this the other day) |
03-25-2018, 07:55 AM | #123 |
Rep 3,297
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
03-25-2018, 12:18 PM | #125 | |
Moderator
7509
Rep 19,370
03-25-2018, 12:19 PM | #126 |
Rep 3,297
"Build it...and they will come..."
03-25-2018, 12:22 PM | #127 | ||
Rep 1,483
Ok well I reckon work from home and play Gran Turismo is the way forward |
03-25-2018, 01:05 PM | #128 |
Rep 39
I don't blame you if you didn't read my overly lengthy response in detail. But EMF measurements in Teslas are on par with any other car. In fact BMWs (with all their electronics, idrive controls, gesture sensors, etc) have greater EMF emission to the driver as explained in my previous post. So even if EMF is proved to be dangerous, EVs still are better for you while driving (larger current draw to your home while charging or at work my be a more valid issue though). Regardless, brake dust and exhaust from ICE are infinitely more dangerous at this point. I have friends with hybrids and EVs that have 80% of their pads left after 100k miles of driving due to brake regeneration. If you are concerned about EMF exposure, you can wear an aluminum foil hat all day (such a simple thing really effectively blocks EMF radiation; also many cars are made of aluminum and thus EMF shielding can be easily made hence the low Tesla readings. Try to shield from exhaust plumes with ICE!).
Besides, from a marketing standpoint with all of the great car manufactures hating Tesla/EVs. Wouldn't it be easier for any one of them (BMW, VW, etc) or big oil companies to say, "Hey WORLD, EVs produce EMF radiation that's potentially dangerous! Don't buy yourself a death trap!" instead of falling behind, realizing their mistake and now investing BILLIONS of dollars to follow Tesla? Every car company knows that EVs are the future and that EVs are safe and not investing in them means the death of the company in the future. Advertising EMF scares would get them all laughed at and they know it. No evidence. EMF ratings from EVs are the same as ICE. Billions in EV investments proves it from a business standpoint. Gotta look at the bigger picture. Long into the future, great ICE manufacturers like Ferrari will either get on board eventually, or just decide cater to the minute amount of enthusiasts that love the intricate workings and sound of the complex mechanical drivetrain. Last edited by Bavariane31; 03-25-2018 at 03:59 PM.. |
03-26-2018, 07:46 AM | #129 |
Rep 478
