02-12-2009, 08:34 PM | #24 |
meh
125
Rep 1,756
Line Segment (as defined by geometry): a line segment is the sum of all point on a line between two given endpoints
Depending on who wrote this problem, those points on the lines that are clearly shown may or may not be considered "end points" |
02-12-2009, 08:35 PM | #26 |
Rep 465
post the answer already.
02-12-2009, 08:36 PM | #27 |
Rep 465
02-12-2009, 08:37 PM | #29 |
meh
125
Rep 1,756
02-12-2009, 08:38 PM | #30 | |
you know he kills little girls like you
390
Rep 892
You don't know what a line segment is. Look at this plus sign: + an addition sign is created by two intersecting line segments not four. So, while your attempt at sarcasm is humorous, it's also wrong. So again, I already posted the correct solution as I intersected every line segment in the puzzle only once, with one continuous line. |
02-12-2009, 08:42 PM | #31 |
390
Rep 892
02-12-2009, 08:43 PM | #32 |
Rep 465
02-12-2009, 08:45 PM | #33 | |
Rep 2,456
02-12-2009, 08:47 PM | #34 |
390
Rep 892
No, I'm not, from Wiki: "In geometry, a line segment is a part of a line that is bounded by two end points, and contains every point on the line between its end points." The addition sign is created by two intersecting line segments. |
02-12-2009, 08:50 PM | #35 | |
390
Rep 892
Again, from Wiki: http://en.wikipedia.org/wiki/Line_segment "In geometry, a line segment is a part of a line that is bounded by two end points, and contains every point on the line between its end points." and I don't think everyone else is wrong in this case, just you. |
02-12-2009, 08:55 PM | #36 |
Rep 2,456
if you think there are only 8 line segments in this puzzle then you completely are missing the point of the game. the perimeter of the yellow area has 9 segments alone. any 2nd grader could draw a continuous line through each one of the 'lines.'
02-12-2009, 08:55 PM | #37 | |
390
Rep 892
No... every point between the two endpoints is on the line segment, as per the definition of line segment, the endpoints are at the *gasp* end of the drawing. Two intersecting lines or line segments share a point by definition. Just because two lines intersect it does not by definition create a new line segment because the point at which the segments intersect was already a point on one of the existing line segments. |
02-12-2009, 08:57 PM | #38 |
390
Rep 892
No... there are 8 line segments in the puzzle. That *is* the point to the puzzle. You've been tricked.
02-12-2009, 08:59 PM | #39 |
Rep 2,456
02-12-2009, 09:17 PM | #41 |
meh
125
Rep 1,756
**Please note: An intersection between two elements (lines, arrays, etc) is defined as the two element having one or more components in common. A point constitutes an element in my case:
this works in the same way that a parabola with equation y=x^2 intersects the x axis at x=0 |
02-12-2009, 09:18 PM | #42 | |
390
Rep 892
02-12-2009, 09:44 PM | #44 |
meh
125
Rep 1,756
