11-13-2015, 07:17 AM | #23 |
Rep 1,409
Pure speculation but could the throttle stabs be a method to find the balance between oversteer and understeer into and out of the corner? Did Senna use this technique in low- torque high-revving cars mostly?
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
11-13-2015, 07:45 AM | #24 |
Rep 310
Drives: 2018 EB F31 2018 LG F80
Garage List 2020 BMW M2 CS [9.83]
2021 Porsche 718 Sp ... [8.50] 2021 BMW R1250GSA [0.00] 2014 Boxster S [0.00] 2013 BMW R1200GS [0.00] 2011 1 Series M Coupe [10.00] |
On a go kart throttle = right foot brake = left foot...
11-13-2015, 08:37 AM | #25 |
Rep 8,339
11-13-2015, 11:54 AM | #26 |
Rep 644
11-13-2015, 12:13 PM | #27 |
Rep 904
He says to rev match you depress the clutch, then downshift while blipping the throttle, then let go of the clutch. I never blip the throttle while the clutch is depressed. That seems like a good way to wear out your clutch. Instead, I shift into neutral then blip the throttle, then down shift, then let off the clutch while I'm pressing the throttle again. Which way do you guys rev match?
11-13-2015, 02:20 PM | #28 | |
Rep 5,578
I'm having a little trouble following twixboy example since there is no reference to braking - but don't worry about applying throttle with clutch pedal depressed. |
11-13-2015, 02:57 PM | #29 | |
Baby-faced Assassin
1203
Rep 152
Drives: when car isn't broke.
As shown in the video, a rev match downshift only requires a single press of the clutch, but requires the syncros to match a larger speed differential. |
11-13-2015, 03:05 PM | #30 | |
Rep 904
I've always been taught to do the double clutch downshift to save my clutch and brakes. Other people say it makes no difference on modern gearboxes and I can just depress the clutch once to downshift, then let the engine do the braking for me as I enter my right turn. For daily driving is there a need to double clutch downshift to prevent damaging my synchros? I have an 2004 Z4 btw, so not as modern as your cars. Last edited by Twixboy; 11-13-2015 at 03:13 PM.. |
11-13-2015, 03:17 PM | #31 | ||
Baby-faced Assassin
1203
Rep 152
Yes. I rev match every downshift to make a turn. See upcoming turn. Clutch in Shift gear Throttle up to rpm Clutch out/feather throttle to match Close throttle Brake (engine and pedal) Turn Open throttle out of corner Quote:
However, assuming you don't blip the throttle, the bold part will wear your clutch as it "pulls" the engine speed up to match the vehicle speed. It can also shock the drivetrain if you pop the clutch out too quickly. (Like shown in the video when he spins out.) Last edited by RJ_; 11-13-2015 at 03:26 PM.. |
11-13-2015, 03:20 PM | #32 | |
Rep 779
11-13-2015, 03:29 PM | #33 |
dances with roads
4738
Rep 4,099
It's such a habit I do it without thinking when downshifting most of the time. If I'm hurrying I'll skip the double dip.
I double clutch upshifts when the gearbox is cold. My Zed does not like to shift when its cold. |
11-14-2015, 01:18 PM | #34 | |
Rep 11,668
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
11-27-2015, 09:13 AM | #37 |
dances with roads
4738
Rep 4,099
I have, and I agree. I kept pulling the shifter in the wrong direction left-to-right; 1st instead of 3rd, that kind of thing. I wanted the shift pattern to be a mirror image. I'd wager that the Brits share our struggles...
