05-22-2018, 03:08 PM | #45 | |
Rep 528
This is no different than an individual running a stand alone ECU like a Haltech or AEM. The big reason people don't do this as much anymore is that the ECUs are so integrated in all the other systems that you either lose functionality or it becomes so incredibly expensive to separate the engine management functions from everything else and run two independent systems. |
05-22-2018, 03:20 PM | #46 | |
Rep 2,942
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
05-22-2018, 03:39 PM | #47 |
Rep 9,160
I'd feel a lot better about this if the one thing Toyota had been in charge of for the GT86, the dual mode fuel injection, hadn't been one of the biggest faults of that car. Probably better to just keep BMW's bits and bytes in place.
05-22-2018, 03:39 PM | #48 | |
Rep 2,758
Viffermike1753.00 |
05-23-2018, 12:29 PM | #50 | |
Rep 3,211
The engine will be tuned to however the Supra is laid out.. |
05-23-2018, 12:30 PM | #51 |
Rep 3,211
05-23-2018, 12:33 PM | #52 | ||
Rep 2,335
Gerald Killmann, the VP of R&D for Toyota said this in an interview. Quote:
Yes, we have no evidence of a NA. Moving on to a slightly matter, in an interview with Tada san, he make it seem that both cars will be tune differently. |
05-23-2018, 12:36 PM | #53 |
Moderator
7515
Rep 19,368
Well if that's a relevant piece of comparison data, then $50k+ B58 powered model is an even bigger problem.
05-23-2018, 12:44 PM | #54 |
Rep 2,335
It wouldn't be that far off from the 370Z NISMO. The 6SP Manual comes in at $45,690 & the 7SP Auto at $47,090, and at the same time undercutting the $69,300 Cayman S by at least $15k.
05-23-2018, 12:51 PM | #55 | |
Rep 2,942
... case in point: The 370z you mention above. It's a 9-year-old design that Nissan shows little to no signs of replacing, and it uses a motor that was never well suited to the platform. Despite the 330-odd HP, it behaves more like an engine for a larger car and was far better matched to the Infiniti G35/37. Besides: If Toyota really wanted to use NA engines across the new Supra range, it has any number of Lexus engines to choose from -- and heck: it could still do that in, say, the hybrid version. Problem is, none of the Lexus engines are well suited to the Supra platform because, well, most of them are based on old tech -- much like the 370z powertrain. See the problem?
05-23-2018, 12:57 PM | #56 | |
Moderator
7515
Rep 19,368
Maybe they put a B58 in the $40k-ish model, and there is an B48 in an even lower priced $30k-ish model. Then they could do the Nismo trick Nissan does and have a top end B58 powered model at $50k-ish. If ynguldyn says there's a B48, its probably going to happen. He's been correctly predicting engines for over five years now. Its no accident he gets stuff right so often - he has access to proprietary data/info. I feel like there is a lot of bet hedging going on with the car that originates from what people want it to be vis-a-vis the original vs. what it is likely to be based on the fact that in many ways, at the end of the day, its a Z4 in coupe form with Toyota sheetmetal stretched over it. |
Viffermike1753.00 |
05-23-2018, 01:00 PM | #57 | |
Rep 2,335
Encase you missed it, I did say I am also skeptical of this whole NA I6. This whole joint project was to save money. Do you think its cheaper to shove in a different motor? Or to lose the turbos and make tuning adjustments? |
05-23-2018, 01:07 PM | #58 | |
Rep 2,335
Sure, if you believe BMW will allow Toyota to undercut the Z4 by that much. |
05-23-2018, 01:09 PM | #59 | |
Moderator
7515
Rep 19,368
Not only that but there is no such thing as "lose the turbos" when you are designing a mass market automobile. By removing the turbos, you are in fact going to "shove in a different motor". Cooling will be different which affects packaging, weight will be different which affects chassis tuning, etc. BMW is already doing all that for the B48, so by using that motor, you get all that for free. Or, just go with the B58 only. But adding a custom motor, especially for the entry level model, makes all of a big goose-egg sense. Again, I see a lot of people wanting to will something into production that echoes all sorts of traits of previous decades-old model, rather than going with the more likely scenario that the two cars will be similar in every way but aesthetics. |
05-23-2018, 01:13 PM | #60 |
Moderator
7515
Rep 19,368
Well, if they aren't going to undercut the Z4, then the whole thing is doomed. The last generation Z4 was $50k to start with the N20 4 cylinder. The N54 model was $60k. A sporty BMW roadster can command prices like that (though not like it once could). I don't see a Supra bringing home that much bacon unless it has serious chops which it won't have short of a miraculous appearance of an S55 or S58.
05-23-2018, 01:17 PM | #61 | ||
Rep 2,335
Who are these people you are referring to? Quote:
05-23-2018, 01:20 PM | #62 | |||
Moderator
7515
Rep 19,368
05-23-2018, 02:33 PM | #63 |
Rep 9,160
There's no ECU difference in the BRZ and GT86 is there? I know they're more closely related than the Supra and Z4 likely will be but it seems like reasonable basis for Toyota selling a bog stock B58.
05-23-2018, 02:35 PM | #64 |
Rep 2,942
Or a hybrid powertrain -- but I think both models will get that eventually.
I think the ECU changes will be more than small because of what I've mentioned earlier. Toyota isn't going to use what would amount to a turnkey BMW drivetrain. It didn't in the FR-S/86 -- a different project since the engine was jointly developed, but to me that's even more reason for Toyota to not rely on turnkey hardware or software -- and it won't here. I think it's important to remember that Toyota is, by far, the larger entity in this partnership. It was the same with Subaru. Toyota appropriated the basic architecture of the flat-4 Subie engine and developed it from there to suit the FR-S' needs -- NOT the BR-Z's. With the powertrains for the Supra, I sense that Toyota will appropriate BMW's Bxx hardware and take it from there to suit the Supra's needs, not the new Z4's. And since the Supra's needs includes tune-ability, that means a far less protected (and probably simpler) software package. Important to remember here is that the Z4 will be a 'vert only, while the Supra will be a coupe only, for at least the first year. That difference will account for some of the price difference; the marque will account for some more. Beyond that, who knows?
mkoesel7514.50 |
05-23-2018, 02:42 PM | #65 | |
Rep 2,942
The Toyota. By far. Whatever Toyota wanted the engine to do, it got it to do. I suspect it will have the same attitude toward the Bxx hardware it's appropriating. The Supra is too important a car to be a slave to BMW's idea of how a drivetrain should perform -- and you know the automotive press will be hyper-analyzing that aspect from the first moment the car is released. In this relationship, Toyota is the bad-ass. Not BMW.
05-23-2018, 02:48 PM | #66 | ||
Rep 9,160
