      05-12-2024, 02:20 PM   #1
paul.j.ghosh
Drives: 2019 M760i xDrive
floor jack minimum capacity
In the market for a floor jack. What is the minimum capacity for a 2019 M760i to lift a corner for swapping wheels?
Any recommendations of manufacturer/model?
      05-12-2024, 07:36 PM   #2
M_Bimmer
M_Bimmer's Avatar
728
Drives: F02 B7, G12 B7, G07 XB7, 911
If you plan only doing corners, then you can go down the street to 1196 East Main Street, and pick up this unit at a docent price if you use their 20% off coupon:
https://www.harborfreight.com/automo...ray-70482.html
It's got dual pistons in the rear....much better than a single piston lift.
      05-12-2024, 07:37 PM   #3
M_Bimmer
M_Bimmer's Avatar
728
If you plan to lift your car front or rear, two tires at a time, I'd recommend the following for the "reach":
https://www.harborfreight.com/automo...lue-56641.html
...and would recommend you get a pair of jacks if you plan to go this route:
http://https://www.harborfreight.com...low-58345.html
      05-14-2024, 02:06 AM   #4
Kilo_one_one
Drives: BMW 740d G11
Just put my summer wheels back on the car, I use one of these (or at least our locally branded equivalent), so much easier than dragging a heavy 3tonne model around.
https://www.harborfreight.com/automo...ump-64545.html
As an aside the lifting points on the 7 are great, big plastic extrusion, easy to see and keeps your jack clear of anything fragile.
