08-22-2021, 08:24 PM | #1 |
Rep 25
I noticed that there is a Li-ion battery under the hood on the passenger's side. (2021 750i … See pic). Dealer says the battery is AGM under the trunk and doesn't know why the Li-ion is under the hood.
If I use a trickle charger meant for AGM batteries, does it also try to charge the Li-ion? |
08-23-2021, 12:16 AM | #3 |
Rep 25
08-23-2021, 10:29 AM | #4 |
Rep 7,539
BMW technical information about the auxiliary batteries. The Aux battery or batteries are used to power additional options and a PCU (power control unit) facilitates keeping the aux battery charged so that it is not left up to the car's main battery.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-23-2021 at 10:35 AM.. |
08-24-2021, 10:08 AM | #7 | |
Rep 7,539
08-24-2021, 08:59 PM | #8 |
Rep 99
08-25-2021, 08:29 AM | #9 |
Rep 7,539
Correct. If using a battery tender to keep your main/starter battery charged...you should hook your connections to the dedicated positive & negative jump start locations under the hood. Remember...the aux battery circuit has a battery isolation switch.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-25-2021 at 08:50 AM.. |
