01-04-2024, 03:47 AM | #23 |
Rep 388
They aren't. You have the right codes: 34-11-6-861-799, 34-11-6-861-800, so use these and dont confuse yourself with all the useless information out on different sites.
01-04-2024, 01:01 PM | #24 |
Rep 74
Received the 395mm calipers, 395mm rotors, and EBC Redstuff brake pads today. Getting closer.
02-12-2024, 07:17 AM | #25 | |
Rep 108
Pros: - money saved when I upgraded brakes and didn't buy new shields - weight saving while driving without shields - better cooling of brakes when the air can circulate freely around them - easier to troubleshoot them damn BMW brakes; measure the rotor thickness, detect possible uneven wear left/right side, allows measuring run-out when that shaking in the steering wheel reappears |
02-12-2024, 04:39 PM | #26 |
Builder of Special Cars
202
Rep 484
02-13-2024, 05:12 AM | #27 |
Rep 74
04-17-2024, 07:29 PM | #29 |
Rep 80
just picked up a 16 g11 750i in canada vin decoder does not have msport brakes when i enter VIN but i have m sport calipers, i have the dark grey calipers, currently has oem 20 inch wheels, i found tire rack has 19 inch xice snows on clearance for a incredible price, yes i know winter is gone. Can 19 inch wheels fit my car?
04-17-2024, 07:37 PM | #30 | |
Rep 388
04-17-2024, 08:14 PM | #32 |
Rep 74
15_bmw_535i12.00 |
Today, 02:06 PM | #34 |
Rep 900
Drives: F32 428i Xdrive
Would anyone know if the m760 rear calipers fit on rwd 750’s? I’m interested in seeing if this setup would work too
Today, 03:42 PM | #35 |
Rep 74
See part #'s below. As far as RWD, I am not sure if your brake set up is the the same of different since I have xDrive.
Today, 06:22 PM | #36 |
Rep 344
Drives: 2019 BMW M760li
The M760 has a much larger rear disc (398 mm) than the other 7er models.
There are virtually no OEM quality manufacturers for this size disc. I’ve looked around quite extensively and have had to use BMW discs for my rear replacements. Found them at reasonable Prices from some online BMW dealers or FCP Euro. The rear set up uses the same rear caliper/pad as the F90 M5 for reference. |
