      09-27-2016, 02:55 AM   #1
oshevtsov
oshevtsov's Avatar
Drives: E90/E60/F10/F15/F16/F32/G11
Tried to code G11 today.
My I-level is S15A-16-07-506, used data 5.94.
Coded usual NBU-related stuff successfully. Also wanted to code OMSA (CAS on F series), but could not find CAS or something at least similar to try. Here is the full list of ECUs:
ACSM5
AMPT
ASD
BDC_BODY2
DKOMBI2
DME_BAC2
DSC3
EGS
EMARS
EPS2
FLM
FZD2
HKFM2
HSR2
HU_NBT2
ICAM3
IHKA4
KAFAS3
LEM
LMV2
NIVI
PCU
RSE_HIGH_NBT2
SAS2
SM2
TV_MODUL
USS
VDP
ZBE4
Any ideas which G11 ECU now stands for CAS in F series?
Thanks in advance
      09-27-2016, 07:28 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
From G11 FAFP:
      09-27-2016, 10:09 PM   #3
oshevtsov
oshevtsov's Avatar
Originally Posted by Almaretto
From G11 FAFP:
Thanks for the idea, will be trying today
      09-28-2016, 04:17 AM   #4
oshevtsov
oshevtsov's Avatar
Observation re VIM. VIM interrupts at 63km/h, as expected. But turns back on at about 30km/h, maybe slightly more.
Is this expected? Ideas much appreciated.
Still no luck with OMSA though. Keep researching...
      09-28-2016, 04:21 AM   #5
oshevtsov
oshevtsov's Avatar
Deleted
      09-28-2016, 07:51 PM   #6
Almaretto
Almaretto's Avatar
2374
Attached are the functions for Auto Start Stop.
      09-29-2016, 07:44 AM   #7
oshevtsov
oshevtsov's Avatar
Thanks. Tried all possible aktiv/nicht aktiv combinations, but no luck...
      09-29-2016, 05:25 PM   #8
Almaretto
Almaretto's Avatar
2374
Strange. The first one if aktiv should be default off. The second if aktiv should be to remember setting when shutdown.
Back to the drawing board.
      09-29-2016, 06:04 PM   #9
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
OMSA is a conversion code to remove AutoStart Stop and not compatible with the SWE.
There is no CAS or CAS-like module. BDC is the central link (ZGW is inside BDC) with remote slave modules. The car also should to be put into Testing and Diagnosis Mode with official service connection software to generate an authorization signal access to most of those control units and networks. The average Gxx has 60 - 70 Master ECUs with an average of 3 slave controllers in each. Load Dumping also needs to be monitored as there isn't any way to prevent terminals from shutting down automatically.
      10-07-2016, 04:34 PM   #10
Almaretto
Almaretto's Avatar
2374
What do you mean by OMSA is not compatible with the SWE? According to the G11 FAFP (fafp_000018f3), OMSA is present. And, I get no error when adding it to HO-word. See available words:
      10-12-2016, 08:47 PM   #11
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
I'll have to look at the latest trimmed update but IIRC OMSA will be accepted but not functional on EU6 emission vehicles (Boolean prerequisite of BSG development vehicle to make it functional)
Almaretto2374.00
      10-12-2016, 09:31 PM   #12
oshevtsov
oshevtsov's Avatar
My car is EU5 (option 161). Do you think it can matter?
      10-12-2016, 10:43 PM   #13
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Does you car have the button to disable below the start-stop?
      10-13-2016, 01:30 AM   #14
oshevtsov
oshevtsov's Avatar
Yes, it does
      10-14-2016, 11:34 AM   #15
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Yes, it does
I would suggest attempting to code it for remember last button setting instead of using a system delete conversion.
      10-14-2016, 02:25 PM   #16
oshevtsov
oshevtsov's Avatar
I tried both DEFAULT_OFF and MEMORY, neither has worked. Or do you mean anything else?
      10-14-2016, 07:38 PM   #17
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
MEMORY is what I suggest. All US cars have been coming that way by default since the year after it first appeared due to customer demand and its exclusion from US Emissions certifications so I haven't looked at that specific change in much depth. Which module (s) did you code so far for this? You have the new Quad Turbo B57 correct and are in the Black Sea Region correct?
      10-14-2016, 07:39 PM   #18
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
See above...
      10-14-2016, 09:12 PM   #19
Almaretto
Almaretto's Avatar
2374
Yes. B57S.
In BDC_BODY2 (CAFD_000017BC):
  • US has TCM_MSA_MEMORY aktiv from factory vs nicht_aktiv in ECE
  • Both US and ECE have TCM_MSA_DEFAULT_OFF nicht_aktiv from factory
Tried setting each, individually to aktiv, as well as both to aktiv. No dice.
      10-14-2016, 09:56 PM   #20
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Yes. B57S.
PM sent.
