03-21-2018, 02:39 PM | #1 |
Rep 106
steering wheel shift
The steering wheel in my car shifts down by about a millimeter when pulled towards me and downwards after starting. I can reproduce it after the steering wheel goes through the cycle of going up and then coming back down achieved by stopping car, opening door to raise steering wheel, closing door, and starting car again to lower steering wheel. Can some of you check to see if it is happening in your car as well?
03-21-2018, 03:07 PM | #2 | |
Rep 527
I'll try that tomorrow and come back to you, but I don't remember any play (movement of a mm even in any direction) when driving off... Are you having to pull quite forcibly to get this movement or is it just from gripping the wheel? Are you at any of the limits of the range of motion in the wheel by chance? (so extended all the way or up all the way, etc...just to try to replicate the situation).
03-21-2018, 03:21 PM | #3 | |
Rep 7
03-21-2018, 03:24 PM | #4 | |
Rep 527
Thanks for the clarification Llewelyn. ^
03-21-2018, 04:41 PM | #5 |
Rep 106
It is a distinct movement as in there is play or a settling of the steering wheel after it has reached it's programmed position. It only happens once after every cycle of steering wheel going up and then coming down upon starting. So, start the car, slightly pull steering wheel towards you and downwards and you will feel a shift of about a millimeter and then it stays put if you were to drive my car.
03-21-2018, 05:02 PM | #6 | |
Rep 527
Hope you get it resolved whatever the reason, to your satisfaction. Have you talked to your dealer about it?
03-22-2018, 12:13 PM | #8 | |
Rep 1,595
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
03-22-2018, 12:30 PM | #9 |
Rep 106
I intentionally pull to feel the give. If I don't pull then I will feel it perhaps as I am turning the wheel or repositioning my hands or using the steering wheel as support to shift myself in the seat or ....
03-23-2018, 10:22 AM | #10 |
Rep 527
Took me a bit longer than anticipated but I've finally been out in the car and given it a try to see if there is any play...none.
I've used more force than I would normally ever put on the wheel as well and nothing in terms of play or movement. Hope that helps as a data point paul.j.ghosh Safe travels and hope you get it sorted.
