05-20-2015, 12:50 PM | #1 |
Rep 2,136
How turbo wheels are made?
I've been wondering how turbo compressor wheels were made. Neat little video showing the machining process...
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
05-20-2015, 03:54 PM | #2 |
Rep 234
[u2b][/u2b]Haha, I actually work as a machinist and program CNC machines for a living. For boutique turbo impellers, yeah they're probably machined from solid. For production engines however, they're most likely pressure-cast, or finely forged parts. There's just not enough time in the world to machine all the required turbo impellers from solid, for production engines.
There's a running joke among machinists that the only thing that a 5-axis milling machine could be used for is impellers. Not true for 5-axis machines, and not true for impellers. But, they do make for neat demo parts... How much HP do you think THIS guy would make??? (Notice how the caption states, that it takes 30 minutes to rough out just one vane... Achieving a fine-finish on the vane surfaces will take HOURS each... Here's another good one... And for the record, these machines cost-in about the same a fleet of new BMW's... |
05-20-2015, 04:42 PM | #3 |
1Addict
3233
Rep 7,894
Regardless of practicality, it was a very cool vid. Pretty impellers too.
05-20-2015, 09:04 PM | #4 | |
Rep 2,136
05-20-2015, 09:44 PM | #5 |
Rep 18,727
I used to buy machine tools for Lockheed Martin. That 5-axis machining center in the video does not look like a high-rate production machining center and looks more like a prototyping machine, or a low-rate production machine at best. Machining turbo fans from billet would be cost prohibitive for high-rate production of turbos. Jashley73 is correct, production-rate parts for turbos are pressure cast, or roto-cast parts.
05-20-2015, 10:15 PM | #6 | |
Rep 234
Efthreeoh, are you still with lockheed martin? |
05-21-2015, 01:28 PM | #7 | |
Rep 18,727
