01-04-2023, 04:15 PM | #1 |
Rep 396
Integral Active Steering / Autobahn Package, How do I tell?
Anyone know if there is a way to identify if a 750i has this based on photos? Dealers mostly don't even know what I'm talking about and it's a must have for me.
01-04-2023, 04:27 PM | #2 |
Rep 18
Left of the steering wheel. Where the fog light button is.
There are 4 squares. If it has a button for all 4 spots (one of which is autobahn mode) then yes it has it. If just 3 out of the 4 squares are filled it does not |
02-18-2023, 10:51 AM | #3 |
Rep 396
Thanks man! Do you happen to know if the Integral Active Steering button is in the same place if you just have that option and not the full AB package? I assume yes but figured I would ask.
02-18-2023, 03:00 PM | #4 |
Rep 417
Left of the steering wheel has only light control switches. These include rotary switch, parking lights for each side, fog lights for front (optional) and rear, and NIVI CID button if equipped with that option. Nothing in there indicates whether the car has Autobahn Package, which is Integral Active Steering and Executive Drive Pro.
Only way to detect integral active steering from photos is to see if rear wheels have turned out, as it includes rear axle steering. Hard to identify it anyway unless photo is specifically focused on that. Executive Drive Pro can't be identified via photos unless those photos are from underside with some aero panels removed so that electronically controlled sway bars are exposed. |
02-18-2023, 03:28 PM | #5 | |
Rep 2
The best way is to do a search of the VIN to find out exactly what options and features the particular vehicle has. Good luck! |
billy.gif22.00 |
02-22-2023, 03:57 AM | #6 | |
Rep 57
Its remarkable big difference to try out. One can disable the IAS even while driving. Try to turn 360 circle with and without IAS active, its like 2 meter / 6,5ft difference with G12 (lang) version! And car needs to move speed over ... 5kmh (or such) before the IAS activates. It wont activate for example when parallel parking or driving very slowly. Not at least in pre-LCI G12. |
02-22-2023, 08:44 AM | #7 | |
Rep 51
02-22-2023, 10:31 AM | #8 |
Rep 396
Hit up BMW with your VIN number and have them send you the MSRP/Window Sticker document. Then you can know for sure what's going on!
02-22-2023, 12:52 PM | #9 |
Rep 51
I don’t think so that I have that. Even I have option for chains.
02-22-2023, 03:10 PM | #10 | |
Rep 417
Integral active steering doesn't only mean rear axle steering, but also variable ratio steering. There is a different, variable geometry front steering rack with this option as well. Whether it is 12V or 24V rack depends on the vehicle variant. Without S2VH option, you have a fixed steering ratio along the steering wheel movement. With S2VH, the steering ratio adjusts depending on the steering angle and is more indirect at center position. EDIT: Attached the functional and technical documentation regarding standard EPS and HSR (Integral Active Steering). Last edited by Raimo5; 02-22-2023 at 11:06 PM.. |
02-22-2023, 09:14 PM | #11 | |
Rep 51
02-22-2023, 11:04 PM | #12 | |
Rep 417
Parking Assistant is not a requirement here. HSR will do it's job within the parameters regardless of who is in control - you or the automation. You can turn it off by selecting snow chain mode as described above, but bear in mind that this disabling works up until 50km/h. If you exceed that speed, HSR is automatically reenabled. |
02-23-2023, 05:11 AM | #13 | |
Rep 57
In newer models the turning angle is up to 5 degrees. |
Rioskis14.50 |
02-23-2023, 06:28 AM | #14 | |
Rep 51
