      02-13-2023, 10:28 PM   #1
Rioskis
Drives: bmw 740Le x drive
drivetrain need help
Hello all.
I need some help. Maybe someone knows what could it be?
If I turn off engine it didn’t come back.
What could be the most problem? I know I should connect obd to check but can I see it if the mistake is gone?
      02-13-2023, 10:35 PM   #2
Raimo5
Drives: BMW 740d xDrive (G11)
It could literally be hundreds of different things. Speculating at this point would be meaningless and most likely would lead you away from actual issue.
Diagnostics tool needs to be hooked up and codes read. If it haven't been done in a long time, I would suggest an erase of all active codes, drive the car until this particular check control message occurs and then recheck and post the codes.
Rioskis14.50
      02-13-2023, 10:40 PM   #3
Rioskis
Thank you raimo. I turned off engine and no mistakes. I can normally drive and the power is as it should be.
Raimo5197.50
      02-13-2023, 10:49 PM   #4
Raimo5
Sorry, I forgot to add the the fault entry will definitely remain in the corresponding ECU, even after you restart the car and there is currently no CC message displayed.
Is this fault condition reproducible or does it appear out of the blue and is intermittent?
Rioskis14.50
      02-13-2023, 10:59 PM   #5
Rioskis
It was one time before. I ignored. And after a week or so it’s appeared again. So now I’m wondering.
      02-14-2023, 06:33 AM   #6
Rioskis
So that’s the codes. On Wednesday they will repair.
      02-14-2023, 07:06 AM   #7
Rioskis
The price for it with work (they said around 7hours) 2400€ here in Finland. But I have insurance that will cover everything so for me it will be 0€😊
      02-14-2023, 09:33 AM   #8
Raimo5
2400€? Gosh that is extortionate. I wonder if they are going to replace the whole turbo with wastegate actuator.
      02-14-2023, 09:37 AM   #9
Rioskis
Yes. Only that electric “stick” 500-600€ the whole 1700 with all gasket needed + 490-560€ for their job. (70€ for 1h)
      02-15-2023, 11:03 PM   #10
finestbm@gmail.com
Drives: BMW X5 F15 750 G12 i4 G26
2023 BMW I4  [0.00]
2016 BMW 750  [0.00]
Checked this
https://bmwrepairguide.com/sib/121916.pdf
Patryk chmielewski
Rioskis14.50
      02-23-2023, 08:07 PM   #11
mitymikec
Drives: 2016 BMW 750
I have similar issues and am trying to find an aftermarket or used wastegate actuator. Anyone have one for sale?
