      03-11-2024, 10:54 PM   #1
jh00@aol.com
Drives: F90
I7 - odd issues
Just got the 2024 i7 and so far it’s been amazing except for the following 2 issues. Has anyone else had these issues? If so please respond and let me know how you corrected them. They are:
1) the car came with the time set to New York which is the region I am in. However I tried to switch it to automatic time setting. Every time I do that it automatically switches my location to thinking I’m in Brazil!! Then I uncheck auto and just manually put back New York. Very strange
2) sometimes when I’m on a Bluetooth call the other person on the other end of the call will tell me they can’t hear me. I then need to go into the phone settings while on the call and set the speaker to “whole auto” I have done this several times but it keeps reverting back. Does anyone know why or what is going on??? Please advise. Greatly appreciated.
      03-12-2024, 12:17 AM   #2
LVBMW
LVBMW's Avatar
1441
Drives: '24 iX M60 '23 Tesla Model Y-P
#1 is a super common occurrence that is afflicting a lot of drivers of different models. Many have noticed since the DST switchover that the auto time zone setting puts them in some far off place.
      03-12-2024, 04:02 AM   #3
JParsonss
JParsonss's Avatar
Drives: 2024 7 Series 760i
Same issue here with auto time zone. It just will not work.
      03-12-2024, 05:29 AM   #4
A-Train
Drives: i7
I had to manually enter the time rather than select a specific time zone, which the car says is not now an available function. Odd; software fix hopefully coming.
deutsch1003991.00
      03-12-2024, 10:24 AM   #5
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
Sane here also
      03-13-2024, 04:49 PM   #6
DroMike
DroMike's Avatar
173
Drives: '24 i7 eDrive50 (Inaugural Yr)
Originally Posted by Gemini7866 View Post
Sane here also
Yes, being stable and of sound mind IS certainly important. Thanks for the personal sharing!
      03-14-2024, 04:28 AM   #7
merclyn
Drives: BMW i7
#2) I had same issue with bluetooth on my 2024 i7
The dealer needed to "Reconfigure or reprogram" something that was not set right at the factory. All good since then
I had other weird things like over air software updated were not working. it would say "In Progress" but never was. That was fixed too.
      03-14-2024, 07:40 AM   #8
jh00@aol.com
Drives: F90
Interesting so when you go into the audio settings while on an actual call does the default show whole car front or rear for the sound?
I have also had issues downloading things they just get stuck for days in the system notifications list. I have also experienced intermittent issues with seeing photos from the app. Sometimes it works and sometimes it just says error
      03-23-2024, 11:01 AM   #9
mobileli
Drives: BMW 740i
I noticed people can’t always hear me well when using Bluetooth. When swinging to apple car play it would be perfect. But my car decides if it wants to be in car play or normal Bluetooth on its own. The buggiest bimmer I’ve owned so far with this aspect.
      03-23-2024, 11:15 AM   #10
A-Train
Drives: i7
Make sure your phone settings microphone is not focused on rear passenger.but instead on front / driver. I'm not sure if you have to be actively a call to make that change. Not sure if that addresses your issue.also, when in phone mode, go to settings then mobile devices then uncheck "rear". Maybe either or both.of above will remedy your issue.
      03-23-2024, 11:23 AM   #11
mobileli
Drives: BMW 740i
I’ll try that thank you
      03-24-2024, 04:13 AM   #12
jh00@aol.com
Drives: F90
Yes I have done that the problem is it keeps reverting back to rear only.
Any word on when they will fix the auto time function?
      03-24-2024, 04:41 AM   #13
A-Train
Drives: i7
I don't use carplay or AndroidAuto. The above fixed things for me. Perhaps ask the idrive specialist at the dealership...
      03-24-2024, 04:43 AM   #14
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
They fixed my auto time these were the notes
deutsch1003991.00
      03-24-2024, 06:49 AM   #15
A-Train
Drives: i7
Gemini7866, thank you for posting that service worksheet. If going to the dealer for necessary things, I'd ask them to do the time zone fix. Otherwise, takes just 30 seconds at home to manually adjust every 6 months / daylight savings switch. I'd hope BMW just has a simple OTA tix... I'd really like it once they let us rearrange shortcuts in the order we want!
      03-24-2024, 06:51 AM   #16
A-Train
Drives: i7
While we're all at it, can the driver adjust the front passenger seat position to slide fore and aft? I know we can adjust seat "shape" and massage but I'd like to be able to slide the seat back and forth on the horizontal plane, to reduce the b-pillar blind spot when driving alone.
      04-01-2024, 10:16 AM   #17
deutsch100
deutsch100's Avatar
3991
Drives: i7 60, XM, M3 Comp, 911 GTS
This was an option in my last three 7 Series (and Ghost too).
Is this no longer doable in the new/current 7? I have not tried this yet.
      04-14-2024, 04:31 AM   #18
jh00@aol.com
Drives: F90
Anyone know if and when the update to fix the auto time will be available?
      04-19-2024, 12:48 PM   #19
Ice4life
Drives: 2024 740xi
Mine allows me to. The rear right passenger can too.
deutsch1003991.00
      04-20-2024, 10:22 AM   #20
patchan8984
Drives: BMW 840iCV, i7 x60
I do this as well, and can only be done on the screen now, after pushing the shortcut for the seat controls. Unlike last gen 7 series where you could just push a button to select the passenger side then adjust with the manual controls., which would have been nice.
      04-20-2024, 01:01 PM   #21
A-Train
Drives: i7
Hmm... I don't see that ability / option in any of the menus. Can you please be very specific as to how you as driver can adjust the passenger seat fore and aft without manually using the physical control hard buttons on the passenger's door? Thank you.
