01-13-2018, 08:16 AM | #133 |
Libertarian
71941
Rep 4,035
Those are momentum cars they dont need a lot of power, you just proved you've never tracked or autocrossed. You're just going by shit you read on line.
01-13-2018, 08:19 AM | #134 |
#buildnotbought
10983
Rep 4,912
Sell your car if you're not happy instead of bothering others.
Or go to a real racetrack instead of playing around on your parkinglot.... Even mercedes is going to use I6 engines again. If you think 4 bangers are better then open a topic called "is an i4 better than an i6?"
01-13-2018, 08:25 AM | #135 | |
Libertarian
71941
Rep 4,035
I hurt your feelings bc i think a v6 will help the 3 series, you need help |
01-13-2018, 08:34 AM | #136 | |
#buildnotbought
10983
Rep 4,912
I'm sure you're a better engineer.....not. Sell your car and buy a miata. Be a man and keep your word!
01-13-2018, 08:38 AM | #137 |
Libertarian
71941
Rep 4,035
01-13-2018, 08:52 AM | #138 |
#buildnotbought
10983
Rep 4,912
If you're so convinced that an i6 is such a bad engine, then how the hell did you end up buying an m4?!?
What kind of stupid thought process was behind that? Forgot to look under the hood?
01-13-2018, 09:34 AM | #139 | |
Libertarian
71941
Rep 4,035
Our cars will really benefit from a V6, being stubborn and doing things a certain way because we always done this way is stupid! Look at the Cayman, it's a better handling car than the 911 but on purpose Porsche sandbags the Cayman's perfomance! It's not magic my friend, you need to understand physics... |
01-13-2018, 10:21 AM | #140 | |
Rep 407
It would be no different to another company making a rotary engine genuinely viable, yet Mazda is the one who has kept the design alive. |
01-13-2018, 11:05 AM | #142 | ||
#buildnotbought
10983
Rep 4,912
01-14-2018, 02:09 AM | #143 |
2JZ-GTE
3069
Rep 4,015
BMWs have in-line sixes and therefore it's a superior motor configuration.
End of story |
01-15-2018, 01:19 PM | #144 | |
Rep 407
Using this kind of tech could allow BMW to improve their weight distribution even more as it shrinks the overall length. Being one of the few consumer vehicles with an I6 does not necessarily make it viable |
01-15-2018, 01:31 PM | #146 |
Rep 9,160
Anyone venture a guess as to what the odd secondary intake on the exhaust side is for?
[img]http://performancedrive.com.au/wp-co...76-440x250.jpg[/img] |
01-15-2018, 02:01 PM | #147 | |
Rep 7,215
01-15-2018, 02:55 PM | #148 | |
Rep 407
I just drew an imaginary line between the top of the wheel centres and there was probably about 2 cylinders past that line. This is the only engine bay shot we have to go on right now so it's hard to guess from the angle. |
01-15-2018, 03:00 PM | #149 | ||
#buildnotbought
10983
Rep 4,912
BMW uses a very neat but oldest trick in the book to solve that issue Quote:
01-15-2018, 06:53 PM | #151 |
Curmudgeon and Pedant
690
Rep 3,489
01-15-2018, 07:02 PM | #152 |
#buildnotbought
10983
Rep 4,912
^you mean that the valvetrain distribution is located there?
or what?
01-15-2018, 07:30 PM | #153 | |
Rep 9,160
01-15-2018, 08:11 PM | #154 |
#buildnotbought
10983
Rep 4,912
yeah bmw has been putting the distribution there for quite some time now on a number on engines, like the n47 and n57. And notably those engines have chain tensioner problem
I dont know what I would do, pull the engine or the gearbox. Maybe the engine on an automatic and the gearbox on a manual. This is the acces from the gearbox side: A good pic to see how much space it takes up. I think from a balance pov this isnt an issue, because the extra space is 2 chains thick (so about an inch I think), in which the chains, tensioner, chain wheels etc run. I think thats just as heavy as any 1inch crossection at any part of the engine. Also the oil pump sits now on that side with its distribution. And those parts need to sit somewhere. If its relative mass is on average as high as the rest of the engine it makes no difference except for servicing. The only advantage I can think of by placing it at the rear is that it may be less susceptible to harmonic vibrations prolonging its life (however one can wonder if thats the case, comparing the n57 valvetrain to my own m54 valvetrain that can virtually run troublefree for half a million miles and where a tensioner is swapped in 10 minutes if needed) What I also was hinting about is that BMW doesnt use an ordinary I6 placement but under an angle, one of the oldest tricks in the book (I think chrystler thought of that back in the 50's). Also called slant (popularly at least), as in slant six. I hadnt seen a pic of that m256 in a chassis but I immediately saw at the shape of the sump that MB wasnt going to do that, further comprimising an effective balanced placement of an i6 into a chassis and a missed oppertunity if designed a performance chassis. Look at this pic and see how low and deep bmw's i6 sits in the chassis and then look again at that merc pic: It sits way below the top of the strut towers, easily fitting a strut brace over it. The merc's placement isnt even near that sort of placement. And if you look even closer there are so many details that bmw thought of (or at least put into their design), for instance, look at these oilpans: m54 oilpan: B58 oilpan (couldnt get so many pics of this, but I found this one to show that placement of the oilpump isnt the issue if the carmaker does his homework): Now look again at that m256 engines oilpan. Spot the difference! BMW placed the deep side of the oilpan (where all the oil sits) behind the front axle. MB didnt. All in all I think mercedes primarely designed this engine for fuel economy, good power delivery, smooth runnings but not a balanced placement otherwise they would have looked more closely at bmw's The more you work on these cars and their engines and the more experienced you get, the more you discover the little details bmw thought of to perfect the balance and handling on these cars. Thats why they build cars with i6 engines that outlandle a lot of the competition with v6 engines, while still profit from the superior points of an i6 like smooth primary and secondary balance, a distict cold side air intake which is good for both power, track stamina and longevity etc etc Having a cold side to an engine also benefits other systems like the brake/brake booster system being able to run colder, which is better for braking stamina on tracks, so various systems interact on multiple ways. In that regard its especially interesting to take a very good look to a TVR with speed six engine or an old jag for that matter as they've incorperated a very very neat trick BMW has mastered all these engineering requirements where a lot of the competition hasnt.
