04-23-2024, 07:33 PM | #1 |
Rep 6
Does lowering via ISTA stick?
Lowered the car via ISTA this past weekend. 20mm a corner.
Looking at it today, it absolutely looks to be raised back up. I haven't measured again, but I would bet money its back to normal. Anyone had this issue? |
04-23-2024, 10:48 PM | #2 |
Rep 859
ISTA has limit on the allowable reduction in height....I don't remember the value, but 20mm is the number that comes to mind....I'd have to fire up ISTA this weekend to check for you...but someone can weigh in to support or correct this claim.
It may try and lower, if the exceedance of the allowable adjustable range occurs, it will only cause the vehicle to use the previous "valid" values, not the new ones you entered....e.g. your new height adjustment will not "stick" Last edited by M_Bimmer; 04-23-2024 at 11:03 PM.. |
04-24-2024, 10:13 PM | #3 |
Rep 20
If your looking to lower your car I would highly reccomend the CETE lowering module: https://tagmotorsports.com/cete-ble-...owering-module
It's a little pricey but it's been an absolute dream! You can lower your car down to -55mm and raise it to +30mm. I used to have lowering springs on my G30 5 series and now it seems like such a cave man thing to have your car lowered ALL THE D*MN TIME. With the module you can even save the lowered height for different modes. Like sport mode can have a lower ride height than comfort. There is also show mode where you can lower you car to -60mm. |
