TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Dontri
Reply
      10-24-2014, 11:01 AM   #1
Dontri
Drives: 06 325xi wagon
Dontri
I have a 06 325xi wagon. When braking at just about any speed my steering wheel shakes. Could this be the front wheel bearings? Also I can feel a slite vibration that seems to act like the one of the wheel bearings is going.
      10-24-2014, 12:00 PM   #2
hockeyplayer
hockeyplayer's Avatar
Drives: 2006 325i, 2006 325xi
You most likely have a 'warped' brake rotor. If its not that it could be some of your bushing in the suspension need replacement.
      10-24-2014, 12:15 PM   #3
Dozhdbog
Dozhdbog's Avatar
Drives: 2011 335i Sedan
I have been told by a racing mechanic that a warped rotor is almost never the case. The degree of heat needed to warp modern BMW rotors is much higher than most people would experience even tracking their cars.
What is most likely the problem is brake pad transference to the rotor, which has caused unevenness. Brake pad transference generally occurs when standard road pads have heated up from extended and spirited driving. Pads designed for higher extended temperatures will not have the same initial "bite" as typical road-going pads, but will give you shorter stops and will not transfer to the disc as readily.
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
      10-24-2014, 12:31 PM   #4
3s4u2
Beamer Mantic
3s4u2's Avatar
Drives: 2006 325i Prem
This..., been there done it 3 times, if it only happens when you apply the brakes you will most likely need pads and rotors. I solved the problem about 75,000 miles ago with these-> http://www.turnermotorsport.com/c-98...ors-discs.aspx Wow there on sale! The xi may have a different rotor setup than my 325i.
2006 325i
2006 M5
2008 X5 4.8i
2014 X5 50i M-Pkg
      10-24-2014, 12:44 PM   #5
hockeyplayer
It should be the same. I have an XI my gf has the I, they use the same parts.
      10-24-2014, 04:14 PM   #6
kiel_dafo_kenyg_as
DIE ANTWOORD
Germany
68
Drives: 335d E92
Rock the front wheels while the car standing on the ground. If you can feel any play have a closer look to the bones.
Reply
