05-04-2017, 07:28 AM | #1 |
Rep 2
Options for a used BMW as a first car
So i've been saving up for some time and i'll be buying my first car for around 6-7k euros in summer. I always loved the way the 5series e60 looked and i am considering the 525d/530d options year 2004-2006. Location is eastern eu, car will be bought in germany. So to any diesel e60 owners, how does it hold up? Any issues that start popping up after certain km? How is the repair-ability and accessibility of this car since all maintenance would be done at an indy mechanic. Any big electrical issues with this vehicle? True or not i've heard that the older e90 and e60's were very prone to electrical issues (don't know the validity of this, as this was said by a mechanic i know) And any other advice or options i should consider would be very welcome.
Thanks |
05-04-2017, 08:42 AM | #2 |
Rep 912
All BMWs are prone to electrical issues. But there are also many gems.
If you want to be certain you're buying a solid car, make sure your indy shop has good knowledge of the vehicle. If not, I'd truly suggest talking to a local BMW dealer and getting a proper look over from someone who is mechanically and technologically familiar with the vehicle. |
05-04-2017, 10:53 AM | #3 |
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
Have you considered a lease? For my little brother so is getting a car this summer; I'm thinking of just leasing a WRX so that I know he has a car that works and is covered in case anything breaks.
But then again, I'm not sure how it works in Europe. |
05-04-2017, 11:42 AM | #4 |
Rep 2
Leasing is basically just called buy-out rent here. Its not worth it for a cheaper car especially for a first one. I simply dont see point in it unless you're buying almost brand new
05-06-2017, 12:32 PM | #5 |
Custom User Title
1135
Rep 675
First car?
If I assume correctly, that means you are young. Get a reliable car that is inexpensive to maintain and repair. Establish yourself in your career and then slowly start to move up in cars. Your retirement fund and the 65 year old version of you will thank you. Prosperity takes sacrifice. |
UPSROD941.00 |
05-06-2017, 03:03 PM | #6 |
Rep 471
I'd get an E30 as a first car. They are less expensive than the newer BMWs, and any money you put in you will get back in utility or resale value, if you can find a nice one. I really liked my first E30 and wish I had never sold it.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
05-08-2017, 01:48 PM | #7 |
Rep 230
There is a local bmw club in Lithuania, google and ask them for a help. Е60 for a 7-8 euros would be a high milliage piece of junk. Especially diesel.
Get yourself something reliable and inexpencive for a fist couple of years of your driving experience.
e36->f48->....
05-22-2017, 09:49 PM | #8 |
Rep 18
Consider an e36 328is 5-spd stick. I still have my 97, about 250k, and it's a blast to drive. Had some suspension and braking mods done, and a CAI...
Not a lot of power, although it can be modded if you want to go that route, but it handles very well, and there are plenty of suspension mods to make it even better. Find one that hasn't been beat to death, garaged so the paint is good, hopefully a weekend driver with no or minimal track use so it's relatively low and low-stress mileage. If it hasn't already had this done, immediately swap the stock rad for aluminum - the plastic necks for the upper hose WILL fail around 100k. Upgrade the water pump as well, either a quality aluminum one or the most recent BMW OEM part, which I understand has had the vanes improved. I haven't had any rust issues, had the clutch rebuilt once and replaced the dash module when the gauges got screwy. Oh - the brake light switch can be a replacement item, cheap. Biggest issue for me has been the quality of the interior - vinyl peeling on the door cards, headliner needed replacing, door cards come loose, general cheap quality inside. I still love the car. Fairly easy engine to work on, I replaced my own radiator, water pump, coolant bottle and switches; plugs several times; valve cover and plug gaskets; upper crankshaft position sensor (that fix brought the car back to new life). |
05-23-2017, 01:07 PM | #9 |
Rep 878
Stick with any N/A inline 6 cyl. BMW that suits your style, then find one that's well documented and well cared for - then give that person your money.
-WJV
Tags |
reliability. first car. |
