03-30-2015, 06:59 AM | #1 |
Rep 156
Spacer Question
Hi
I used the "tape method" to measure the spacer size needed. However I got 2 results. If I measure from the upper part of the sidewall the result is 30mm if from the middle part it is 25mm So what spacer size should I get? Really want that WIDE STANCE. |
03-30-2015, 07:07 AM | #2 |
Rep 3,947
LOL. Why? Looks over function? Hellaflush #yolo.
03-30-2015, 08:47 AM | #3 |
Rep 156
03-30-2015, 03:54 PM | #4 |
1Addict
3233
Rep 7,894
It's not the same as getting wider wheels with a better offset. Your suspension is designed to work on load through the hub, not on load through something sticking 25-30mm lateral to it.
