01-17-2017, 08:20 PM | #1 |
Rep 2,476
Drives: Satan's Chariot 2.0
Recommend a power washer & jump starter
I've been meaning to get a power washer for a while, but keep forgetting about it. It'll be used for washing cars, washing house, etc.
Also, after the alternator going out in the Miata, it's time to stop procrastinating on getting a jump starter to carry around. Thankfully, I wasn't far from my destination & my friend came & jumped me. I've seen a ton of them online for under $50 so what is good & reliable? |
01-18-2017, 05:11 PM | #2 |
Rep 2,476
No one huh?
01-18-2017, 06:13 PM | #3 |
Rep 13,763
I have one of these portable jump starters. Really multi-functional.
https://www.amazon.com/dp/B015TKUPIC...s_ad_dp_asin_1 As for washer. I didn't heavily invest into one, but got this one for $60 a while back as a deal, and it has been great so far power washing the cars. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
~loud noises~
Never_Enough2202.50 |
01-19-2017, 03:04 PM | #4 |
Rep 1,413
Drives: 2020 X3MC
I have a gas pressure washer for the house and cleaning the deck, sidewalk, etc around the house and bought an electric Ryobi for washing the cars with a foam cannon. The gas washer is way to cumbersome and loud to drag out for cars and most electric ones don't have the oomph needed for house stuff unless you spend over $1000 and then I'm not even sure.
As for the jump starter, I have one of those little lithium ones as well and it works great plus it can charge phones and has a flashlight for emergencies. |
01-19-2017, 05:53 PM | #5 | |
Rep 2,476
01-19-2017, 06:27 PM | #6 | ||
Rep 1,413
Drives: 2020 X3MC
https://www.walmart.com/ip/PowerAll-...liath/51232584 |
01-19-2017, 07:58 PM | #7 | |
Rep 2,476
01-20-2017, 10:02 AM | #8 |
Rep 2,476
Anyone using the Harbor Freight jump starter?
01-20-2017, 11:24 AM | #9 |
Rep 876
Under $50 is gonna be tricky. You want to buy the most peak amps you can find.
I bought several of these last year as gifts and kept one for myself. 800 Peak amps. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I've used it on our Land Cruiser and it worked just fine. Regarding the power washer, it all depends on what you need. i've gone through 2 junky electric ones (probably ~ $80 each, lasted 1 year max) and finally ponied up for a gas unit. Couldn't be happier. I'd just look for one with a Honda motor for piece of mind. Lots of different pump designs though so you have to pay attention to that as well. |
01-20-2017, 11:37 AM | #10 |
Rep 6,196
As for the pressure washer, one small tip. The "pressure rating" is pretty much meaningless, what really matters is the GPM rating. High pressure and low GPM and you are using the equivalent of a waterpic.
01-30-2017, 07:38 PM | #11 |
Rep 2,476
Looking at these washers at Home Depot
http://www.homedepot.com/p/Sun-Joe-P...3000/204202850 http://www.homedepot.com/p/Ryobi-170...4122/203800590 http://www.homedepot.com/p/Briggs-St...0600/300423908 http://www.homedepot.com/p/Briggs-St...0654/300382834 http://www.homedepot.com/p/Campbell-...0100/207085884 http://www.homedepot.com/p/Sun-Joe-P...1500/300349610 http://www.homedepot.com/p/Campbell-...0100/207085885 http://www.homedepot.com/p/AR-Blue-C...R527/204072257 |
01-31-2017, 11:16 PM | #12 |
Rep 204
Go with a gas pressure washer. Electric ones just don't push the GPM for washing cars, houses, decks etc....
You generally want one that is 2.5gpm+. I have a Generac 5993 and it works great for washing cars, the driveway, deck and other things that you want a lot of water flow. |
01-24-2018, 02:39 AM | #13 |
Rep 1,846
Is it true that anything over 2500 psi is bad for paint? Most gas pressure washers push 3,000+ psi correct. Is this true? Sorry for dumb questions, new guy just learning vehicle maintenance as I am in market for my first pressure washer.
01-24-2018, 06:56 AM | #14 |
Rep 131
A high PSI can strip off paint, damage wood and concrete, if not used properly. However, the good thing about a higher powered gas pressure washer is that since they have a pressure adjustment valve, you can dial down the pressure. The other positive is that although you probably could wash a house or driveway with an electric, it will take a longer time to do so than with a higher powered gas one. As with many other powered tools and toys, there's no substitute for cubic inches, horsepower, torque, PSI, etc. If you can, borrow or rent an electric washer, and a gas washer and do a side by side comparison, and see what best fits your need.
"Horsepower is a terrible thing to waste."
01-24-2018, 07:11 AM | #15 |
Rep 131
01-25-2018, 07:25 PM | #16 |
Rep 2,134
I personally have had this one since like 2010. Just simple maintenance and running perfect. Starts on the first pull still.
https://www.northerntool.com/shop/to...4735_200594735 |
