11-14-2014, 10:48 PM | #1 |
Rep 2
Retrofit Heated MSport Steering Wheel F01
I have a 2012 750i MSport. Is there a way to install a heated MSport Wheel, switch, etc., to have a heated steering wheel in my 2012 750i ? What needs to be purchased to get this done. ...also I have factory warranty and CPO until Jan 2018...so would it only void the warranty on the steering wheel section ?? I appreciate your help, links, videos, etc. progress@tds.net Thanks, Vern Last edited by Vern D; 11-16-2014 at 08:36 AM.. |
11-17-2014, 09:56 AM | #2 |
Rep 659
Drives: '22 M5CS, '00 M5, '06 Z4M
Garage List 2022 M5CS [0.00]
2001 BMW 740i [0.00] 2006 BMW M Roadster [0.00] 2012 BMW X6 3.5i [0.00] 2006 BMW 325xi [0.00] 2017 BMW 540xi [0.00] 2000 BMW M5 [0.00] 2001 BMW X5 4.4i [0.00] |
You will need the following
1) Heated steering wheel with switches about $700 to $800 online 2) SZL module (this has to be ordered with option code S248) - about $450 online. This is the unit on the steering column that has your turn signals, cruise control, etc. 3) New Clockspring with option code S248 - this may come with SZL, check with parts dept 4) Heated wheel button on column - you may need to change the clamshell (upper/lower pieces) that cover the column -check with parts dept. After you install all the components, you will need to have the SZL module coded to the car and have the steering angle sensor aligned. If you decide to give this a go, let me know as I have a X5 that I would like to retrofit this to. Chris
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
