01-01-2019, 03:19 PM | #221 |
Rep 14,521
over the Holiday break worked on the photo collage wall. We originally were gonna just hang the frames on the wall but decided to give it some character. so we used textured wall paper to give it some depth as well as painting it darker as an accent wall to the Family Room. Still ordering some photos for the frames with no pictures but we did pickup some matting borders. had one of my boys help me with the wall paper
here's a close up of the textured design and painted! here's the frames spread out on the floor to give us some ideas on how to place them on the wall. all the empty frames I actually painted them gloss white as they were this brown wood color. also towards the bottom the smaller frames were also a wood color which I ended up painting silver. the "Blessed" sign the frame was also a wood color but I ended up painting it silver also which turned out pretty cool as it still shows the wood texture to it and here's what we ended up with
01-01-2019, 07:35 PM | #222 |
Rep 11,144
That's quite an intense wall!
lsturbointeg9165.00 |
01-01-2019, 11:36 PM | #223 |
Rep 14,521
It's the only wall in the house with photos.
P111582.50 |
01-02-2019, 12:09 PM | #224 | |
Guest
Rep n/a
Drives:
Do you know the dimensions of your closet by chance? Have any more pics? Mine looks to be about the same size and I'm trying to figure out whether to stick with/add more of that junky wire rack to maximize space or if I should go the ikea route with racks/shelves instead. TIA! |
01-02-2019, 12:25 PM | #225 |
Rep 4,836
01-02-2019, 03:18 PM | #226 | |
Rep 14,521
that's all the pictures I took I believe. that's what I originally had was those wire racks which looks sooo cheap. like I mentioned I did 3 Reggior's and 2 Hemnes cabinets on each end. all doors can be opened fully without hitting the shelving unit I built on the other side. plenty of room to walk through to either side. closet looks like a million bucks!
01-02-2019, 03:21 PM | #227 |
Rep 14,521
being a previous Contractor this is very common. he's within code since he has the fireplace glass cover in front preventing any fire hazards. it's a fireplace...the whole house is a combustible
01-03-2019, 07:46 AM | #228 | |
Rep 4,836
The original fireplace/mantle was likely built to code during the initial construction of the home. As a contractor, you would know that building codes have become more restrictive over the years regarding fire safety concerns. I would suspect there is a minimum of 12 inch clearance required between combustable materials and a masonry fireplace. |
01-03-2019, 09:29 AM | #229 | |
Rep 1,965
01-03-2019, 10:44 AM | #230 | |
Guest
Rep n/a
Drives:
I recently completed a storage closet that was 92"H x 25"D x 128"L that I used 12' x 5' raw MDF sheets for but prep, paint, trim molding, etc. was a huge PITA and I'd rather just cut & install pre-finished pieces the next go around. |
01-03-2019, 02:43 PM | #231 | |
Space Force - 4 Star General
11470
Rep 3,264
King Rudi13157.00 |
01-03-2019, 02:54 PM | #232 |
11470
Rep 3,264
Heck, might as well post my fireplace renno:
Before After After Plus Sophie |
01-03-2019, 03:12 PM | #233 | |
Rep 14,521
01-03-2019, 03:17 PM | #234 | |
Rep 14,521
I found a picture of the wire racks before the upgrade
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 01-03-2019 at 03:25 PM.. |
01-03-2019, 03:24 PM | #235 |
Rep 14,521
Looks awesome! I changed mine out too since the original owners had a tv sitting above the fireplace. I ended up closing it in and continued making the mantle look complete from the middle to the top which flowed well with the top crown moulding I did
here's the before: and after:
01-04-2019, 07:58 AM | #236 | |
Rep 4,836
01-04-2019, 08:36 AM | #237 |
Guest
Rep n/a
Drives:
01-07-2019, 03:23 PM | #238 |
Rep 14,521
a few pictures of the closet since I have it loaded with clothes
enough space on top for these designer storage containers that the wife requested my shoe shelf here's the casing I used as a face or bookshelf to make it look nicer than just no face and finally picked up some LED interior lights that change color with a remote that I picked up at Sam's Club. kinda cool if you ask me
01-07-2019, 05:24 PM | #239 |
Rep 1,966
I call this room my Alcohol, Tobacco & Firearms room
I don't have a before pic but it's in the basement, cement floor, cinderblock walls and open ceiling.
01-07-2019, 05:25 PM | #240 |
Rep 1,966
Home Theatre
Another part of my basement, the TV is between two cement posts so I incorporated them to recess the TV and get a bit more distance from the couch opposite.
You can see the ATF room in the background. Last edited by Grumpy Old Man; 01-07-2019 at 05:54 PM.. |
01-07-2019, 06:26 PM | #241 | |
Rep 2,548
Drives: '08 135i, '88 325is
Nice! I really like the ATF room.
Delivered in Munich, broken in on the Nurburgring.
Grumpy Old Man6483.50 |
