08-21-2015, 09:50 AM | #23 |
Rep 1,125
Right...that's why BMW decided on the M6 for it's next GT3 with power coming from production motors
http://www.topspeed.com/cars/bmw/201...-ar165671.html |
08-21-2015, 09:52 AM | #24 | |
Rep 936
08-21-2015, 09:54 AM | #25 |
Rep 936
To OP if you seem to really want to do it. Noones gonna say your silly. In the end of the day there may be 1 or 2 who have done but it's not something done on the regular because of all the points people and you have brought forward. really it's not the ideal car. But I'm sure it could be done.
08-21-2015, 10:19 AM | #26 | |
Rep 823
My point is that it really isn't a heavier car. The difference is minimal. KMS builds a killer s85 race engine as well! |
08-21-2015, 10:20 AM | #27 | |
Rep 823
08-21-2015, 12:20 PM | #28 | |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
The s85 is a great motor but they do have a lot more reliability issues than the s65. I was doing quite a bit of research on the s85 before doing my s65 swap and while it has more power, it is around 80lbs heavier than an s65, has oil pump issues and a few other problems. It was the wrong motor for my car from a balance perspective. S85's are also more common than s65's as not only has the platform been around longer, the cars have aluminum frames and are written off as salvage's much easier than the e9x's. I would be curious to the exact benefits of the e9x suspension vs the e6x. The e9x really comes from the generation after the e6x and i imagine the benefits are equal to that of the e46 to the e9x. |
08-21-2015, 12:25 PM | #29 | |
Rep 823
I just find it interesting how the e63 chassis is pretty much the same weight as an e9x chassis but with a more powerful engine. I guess it could be rarity of the e63 cars but if anything that makes it more special. Another question I was looking for input on is exactly what you mentioned, what are the suspension differences. And do those differences make either chassis more capable than the other. |
08-21-2015, 12:28 PM | #30 | |
Rep 4,744
I think the main reasons the e9x is a more natural choice: - s85 requires more maintenance and is less tested - e63 weighs more / is bigger - e63 has inferior suspension to e9x - e9x has more aftermarket support - e9x w/ 4.6L stroker combined with being ~70lbs less = better choice Also, the weight numbers I found showed the e63 weighing 287lbs more than the 6MT e92. |
08-22-2015, 05:28 PM | #31 | |
Rep 11,891
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
08-22-2015, 06:39 PM | #32 |
Rep 9,160
I'm sure it's not an insurmountable issue, but weren't manual E6x cars unable to turn off DSC? I thought the manual ones always got terrible reviews because of this.
I'm sure software must be able to correct this, but I think BMW gave some goofy excuse that since the S85 was designed solely around the awful SMG, they weren't able to turn off DSC for the manual. And when did an E9x M ever weigh 3,700 pounds? |
08-22-2015, 06:58 PM | #33 | |
Rep 11,637
-I agree that the s85 is less tested as a unit but the s65 is simply an s85 with 2 cylinders loped off. -The M6 does weigh more and is bigger but not by much...less than 2%. This is more than offset by the HP advantage. -I disagree on the suspension. Adjustable makes it approximately equivalent. As in all cars, tire selection is critical. -The aftermarket support is irrefutable. Lower price point, much different age and socioeconomic demographics as well as much greater manufactured numbers lend to this fact. I track my M6 fairly often and pass M3's on the straights and in high speed curves all the time. In tighter, more technical turns the M3 is superior. The HP advantage of the M6 is hard to beat. E63 M6 3,770 lb (1,710 kg) Coupe 4,420 lb (2,000 kg) Convertible here are the weights of the e90 M3 for comparison: Coupe: 3,704 lb (1,680 kg) saloon: 3,726 lb (1,690 kg) Convertible: 4,145 lb (1,880 kg) |
08-22-2015, 07:31 PM | #34 |
Emperor
1613
Rep 2,753
Bigger drives bigger regardless of weight.
Aftermarket support is hugely important to tracking. Bigger cars eat through more of everything-- tires, brakes, gas. Engine is less reliable. They're ugly. BMW disabled dsc because they said the trains wasn't reliable if people were allowed to drive with dsc off It's harder to work on, and track cars need a lot of working on Larger cars just feel worse and out of place on track. You have less options for car placement. |
08-22-2015, 07:36 PM | #35 | |
Emperor
1613
Rep 2,753
08-22-2015, 08:22 PM | #36 |
Rep 2,400
I've thought about this before...the issue I've had is finding a 6sp MT, but conceptually I think the idea is sound. Given the relatively low weight, if you focus on real unsprung weight reduction (wheels, tires, brakes, D/A suspension... I bet you can get 100 lbs out maybe more), it probably will be as quick around the corners as anything out there and the straights will be faster than nearly everything. This would be pretty quick car, IMO.
08-23-2015, 10:03 AM | #37 | |
Rep 381
