BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Comfort Access Retrofit Project
Reply
      12-12-2023, 05:19 PM   #551
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
487
Drives: BMW
Yet another wiring harness for e90 + door wiring
      12-18-2023, 10:33 PM   #552
smass
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
I can't get comfort entry, comfort exit and trunk unlock to work. The car starts fine with the new CA key. Below is the CA coding from the CAS. Should any of the disabled parameters be enabled? Thanks!
KOMFORTSTART
aktiv
KOMFORT_EIN
aktiv
PASSIVE_ACCESS
aktiv
PA_CONFIG_FBDREFCHECK
nicht_aktiv
PA_TVRERFATH
wert_01
PA_TSPERRVR
wert_01
PA_TBEREITPE
wert_01
PA_ID_GEBER
wert_01
PA_FBD_REF
wert_01
PA_TBEREIT_PG
wert_01
PA_CHIPCARD_ACTIVE
aktiv
PA_DISABLE_HK_REV
nicht_aktiv
PA_HK_BACK_IR_SEARCH
nicht_aktiv
PA_HK_INTERIOR_SEARCH
nicht_aktiv
PA_HK_PGS_SEARCH
nicht_aktiv
PA_HK_REOPEN_CTL_DEP
aktiv
PA_HK_REOPEN_CTR_LOCK
nicht_aktiv
PA_HK_RSCR_ACTIVE
nicht_aktiv
PA_SILENTTIMEOUT
wert_01
PA_HK_REOPEN_INDICATE
aktiv
PA_HK_REV_ZYKL
aktiv
PA_MONITOR_ACTIVE
nicht_aktiv
PA_HA_SEARCH_ACTIVE
nicht_aktiv
PA_TRUNK_HIGH
aktiv
PA_SUPERRANGE_R56
nicht_aktiv
PA_TAGE_REAR_RL_MIRROW
nicht_aktiv
PA_LF_PING_TAGE
nicht_aktiv
PA_MAUT_CLOSE_SILENT
nicht_aktiv
PA_SEARCH_HK_VORRASTE
nicht_aktiv
PA_SILENT_TO_4TAGE
nicht_aktiv
PA_HK_2SEARCH
aktiv
PA_LF_PING_PGS
nicht_aktiv
RSSI_THRESHOLD
wert_02
CCM_0X42_IM_NACHLAUF
nicht_aktiv
      12-21-2023, 10:51 AM   #553
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
487
Drives: BMW
CAS needs to default coded. Your problem
Is the cloned key
      01-03-2024, 03:25 PM   #554
smass
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Is the cloned key
You were correct. The issue was with the cloned Chinese key. I had the same locksmith come back. This time I had him used an unlocked OEM BMW CA key from eBay. Now the door handles work fine.
I wish I could have used the correct procedure to order a key from BMW but unfortunately my CAS had already been used with cloned non CA keys.
thanks
      01-05-2024, 11:46 AM   #555
MrNik86
Sh*t Box Connoisseur
MrNik86's Avatar
Drives: E90 Pre-LCI 335i Manual
Hi! I really want to do soft close and comfort access on all 4 doors of my 335i. I bought the passive go module off eBay but found that I don’t have a plug or harness for the comfort access module. Is this something you can supply? I can’t PM yet.
      01-09-2024, 12:13 PM   #556
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
487
Drives: BMW
hi
i ve sent you a PM
      02-03-2024, 03:03 PM   #557
iulian_brz
Drives: Bmw e60 525d
Another harness for 3 series will be shipped to Germany tomorrow
Hi Dumitru, can I talk to you? I need a key for comfort acces! Thank you, email: i.barzu06@gmail.com
      02-03-2024, 03:05 PM   #558
iulian_brz
hi
i ve sent you a PM
Also cable set for soft close!🙏🏻
      03-05-2024, 02:24 PM   #559
scroller
Drives: 335i
Hello,
I have done the comfort access retrofit after 2-3 months of work on my own. So i have purchased 4 door handles from E70 - E70 modules to work for every single handle to work unlocking and the only options is to lock from the front doors only driver and passenger i wasn't happy that, because i wanted to have like e60 when you want to open the rear door only the car is opening the door you want which is a shame but you drink a cold water and continue the journey, the important things to have is the bushings that are on the handles that go into them are very important, I had forgotten them and had to buy them from the scrap yard. I haven't changed the CAS module, because I wanted to have after the retrofit 2 clone(which are not original) keys and 2 original keys which the car was made with. The second task how to put the antennas which are in the interior of the car, because first i have followed diagram for e90 and when i the front antenna the car dont wanted to start, because the signal from the antena which is below the cigarette wasn't able to catch the signal to remote start the engine that's why i have put the antena between the CIC and the cigare button and i have used only 2 in the interior and 2 in the trunk and one behind the rear bumper. My personal opinion about the project is not worth it to have it, because the price of the second hand items is ridiculously overpriced. I have spent like 1000 lv and more 554,97 when you converted to USD. The conclusion is now i have 4 keys which 2 are for comfort access and 2 original keys, 4 door handles with comfort access option. Is it really worth it? What's your opinion about it? Let me know what you think? Every single experience is different compared to the others. I can post some videos and images in the following weekend. Thank you and have a nice reading and good luck to all.
      04-05-2024, 10:51 AM   #560
scroller
Drives: 335i
Hello,
I have uploaded a video how its working the comfort access and soft close.
https://www.youtube.com/shorts/BYJeexWDMMc
      04-25-2024, 01:16 PM   #561
Beemermane
Drives: E92 335i; E90 325i; E60 530
2008 BMW 335i  [0.00]
Hello Dumitro could you please send me a PM?
I have a 2008 E92 and already have the handles, antennas, module. Also I’ve been using ISTA and NCS for a while now. Looking to get the harness for the CA system. Thank you
      04-25-2024, 11:56 PM   #562
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
487
Drives: BMW
Pm sent, thanks
      Yesterday, 12:04 AM   #563
Mesosot
Drives: Bmw e92
tungkaka - i sent you PM with my email address
thanks
Can you send me too ?
Reply
