Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > E93 Scratches on Rear Cupholders
Reply
      04-12-2023, 09:57 AM   #23
pedro2u
pedro2u's Avatar
Drives: '11 E93 M3 6MT, '08 E92 335Xi
Originally Posted by AlpineE93 View Post
Just went and tried, this method took me about 1 min. Close one side of the cup holder, get the smallest flat head screw driver possible (like super fuckin tiny) wedge it between the clip and the base of the cup holder and pry.
I struggled to replace mine without success yesterday... where in the pic is the clip and base you refer to? I've stuck flat tools in every crevice it seems, and pry tools all around the outside! I have the replacement part in my hand and can't see any obvious places that a clip would engage
Appreciate you've successfully done this and can share the magic!
Pete
S65Hunter1187.50
      04-13-2023, 08:26 PM   #24
S65Hunter
S65Hunter's Avatar
Drives: 2009 E92 M3
  [0.00]
"]https://ibb.co/bdBfpFJ][/url][/URL]
2008 328i e93- 3SIM, StageFP tune, magna flow #12148 muffler + vibrant resonator, BMS filters, Bilstein B8s, H&R sport springs, ECS sway bars, whiteline rear subframe bushings, rouge engineering trans mounts, custco front strut bar, M3 front lower control arms. Cosmis R1 18x8.5 245/40 front 18x9.5 255/35 rear.
      04-14-2023, 09:17 PM   #25
christosPap
Drives: BMW E93 328i
Thanks for the picture. I am also having problems taking the cup holder out. I tried prying at the points you are showing, but I had to stop because I felt I was getting close to braking it.
I plan to paint it in situ, after I cover the rest of the area.
      04-26-2024, 02:18 AM   #26
T_M
Drives: 335i e93 LCI
Just finished replacing mine, and found a very simple method to undo the hinges. Insert flathead screwdriver into the slot and twist/rotate it so the screwdriver is causing the main body to flex inward away from the hinge. It literally just pops up and out when you do that.
Reply
