BMW 3-Series (E90 E92) Forum
N54 Dyno Chart Compilation
08-06-2010, 03:58 PM | #1 |
Rep 4,647
trying to make this as "sticky" so that people can post their dyno chart with list of mods. i am fully aware of the fact that there are similar posts like this but most of them i've came across had ugly ends with pissing war between JB and Procede.
the purpose of this specific thread is not to see which is better, faster, quicker, higher hp. simply, just post your numbers just like N54 drag time compilation thread and have people to see what to expect. just post your numbers and mention your mods(Stock, tune, upgraded turbo, meth, nitros, race gas), type of dyno (dynojet, mustang dyno, dynapack, dd etc etc), condition of the dyno day (humidity, elevation, time etc etc), dyno done at what psi and what gear pull and or whatever you feel that is necessary. again, lets keep the discussion at minimum and please post your dyno chart along with it. my intention here is for general public to see many dyno charts possible, not to have pissing war between tuners, so, for tuners and their dear supporters, unless you are posting your own dyno chart, please keep the bashing, discussion minumum.
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers Last edited by hun77777; 08-06-2010 at 04:29 PM.. |
08-06-2010, 05:17 PM | #3 |
Rep 2,428
2008 E90 335i
Baseline of 265hp/280tq PROcede v4 Autotuning AMS Intercooler AMS Catback Exhaust VK Downpipes CP-E Charge pipe/Tial BOV DCI 100 octane ~19psi Performed 5-6 good 3rd gear pulls before the dyno runs, but Autotuning was still learning on the third run JB3 dynos are with same bolt ons on Map 7 on Pump Gas. (15-16psi) Last edited by BrianMN; 09-05-2010 at 02:37 PM.. |
08-06-2010, 07:40 PM | #4 |
Rep 220
Ultimate Racing exhuast
Ultimate Racing downpipes Ultimate Racing intake Ultimate Racing bov Jb3 2.0 AEM methanol kit Pump gas with 100 percent meth |
08-07-2010, 01:06 AM | #5 |
Rep 986
Mods and settings:
* 08 E92 335i 6MT (4th gear) * MSD81 w/Original 29.2 * Vishnu V4 5/15 Autotune * No Meth - UT 55 - IC 40 (15.5psi) * Meth - UT 75 - IC 0 (17.5psi) * Vishnu DCI * AR Catless DP * Helix FMIC * Vishnu Meth Kit (70/30 mix) * Stock CP/DV * 3/8-Tank Trick 101 Octane Conditions: * 77.23 deg F * 30.08 in Hg * 24% humidity
2008 E92 MT | VTT Stage 2+ 20T | VTT Inlets | JB4 MHD E85 | Fuel-It Stage 3 LPFP w/FPR and Return | BMS PI | AR DP | AE Quad Exhaust | Helix FMIC | ER CP | Tial BOV | DCI | AR OCC | Spec Stage 3+ | SMFW
08-07-2010, 11:07 AM | #6 |
Rep 2,428
08-07-2010, 12:48 PM | #7 |
Rep 824
V4 05-15-20 autotuning map running 17 lbs. of boost, 0% IC.
Fuel: Sunoco 110 oct. leaded N2O jet: 0.32 (0.28 on run 29) controller: Dynotune single stage controller to turn on @ 3500, off @ 6500 wheels and tires: heavy ass 19# Beyern Mesh and Nitto 555s N2O bottle pressure: 900 on run 33, 700 on run 29 other: methanol injection 75/25 mix, twin nozzle setup with an M10 nozzle as primary and an M7 secondary nozzle to be triggered with the N2O. Most bolt ons. I wasn't able to change my spark plugs before the dyno runs (I had about 10,000 tuned miles on them). That's why we saw a misfire and had to stop at 6300 rpm. |
08-11-2010, 01:26 PM | #9 |
NF@ E82
28
Rep 264
135i 6mt
JB3 2.0 18ohm, Custom Map 1 AR downpipes Custom 3" Exhaust BMS Intake Active autowerke IC & piping Stett charge pipe Coolingmist meth kit 99% methanol with a splash of water 93 pump gas 77 degrees ambient, %? Humidity; it was raining Baseline dyno was 295/297 bolt-ons w/ no tune
NF@ Jet Black E82 N54
451Whp/448Wtq @19psi; Pump gas & Meth JB3 12 OHM Tuned by: Terry Burger http://www.youtube.com/user/E82jxk |
JuniorB184.50 |
08-11-2010, 04:33 PM | #10 |
Joint Chiefs of Staff
4922
Rep 115,999
JB3 2.0 with bolt ons, 91 octane, map 7 and JB3 2.0 with nitrous, meth, and race gas.
Also the third graph shows customer same car dyno comparison of JB3 and PROcede, all bolt ons with 93 octane, each with custom tuning Mike . Last edited by Mike@N54Tuning.com; 09-05-2010 at 02:20 PM.. |
JuniorB184.50 |
08-16-2010, 09:37 AM | #11 |
MAAD HEAD
62
Rep 1,128
SHIT!!!!!!!
F10 M5 e70 X5M
Sold E90 335i |
08-19-2010, 12:04 AM | #13 | |
Rep 2,428
Mike- Can you provide any insight to this dyno/graph? Every other N54 dyno I've seen drops off HP at 5500rpm, whereas this one keeps climbing til '6700' rpm. Also, it appears this engine has a rev limiter of 7350rpm.. or something that makes the graph appear to fall off at 7350 instead of 7000. Maybe DynoDynamics just read/show rpm and power funny? Can you explain at all? |
08-26-2010, 04:26 PM | #14 |
Rep 28
e90 auto 30k miles
003 run DCI only 93 pump (freaky strong stock, my friend with 335i e92 full bolt ons stock tune 6spd only put down 292whp right after me) 007 run dci jb3 1.4 map 7 100 octane 005 run dci jb3 1.4 map 8 100 octane |
08-31-2010, 05:11 PM | #15 |
Rep 1,054
Jb3 2.0 7/4, Ar Down Pipes, AeM Dual Cones (dry), Hyperboost DV's, Labonte Progressive meth, DO 250psi pump, Cooling Mist M 5 and CM 5 Nozzles.
This isn't my fastest 1/4 but it is one of the highest WHP @ 435.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
09-05-2010, 01:25 PM | #16 | |
Rep 9
When you did those runs? |
09-05-2010, 02:22 PM | #17 |
4922
Rep 115,999
Here is a recent dyno of my car..
The car is modded as follows 335i [This is the Northern BMS testing car ] Street Tires, 19" M6 Rims JB3 2.0 - 18ohm board (7/4 Firmware) - OFF the Shelf maps (no custom tuning run today) PUMP Gas - Sunoco 94 Coolingmist VC-2 Meth Kit (CM7+CM5 dual nozzle setup into an ar design Meth Elbow [90/10mix]) ar design catless downpipes with STOCK exhaust Helix FMIC Forge DVs BMS DCI |
09-05-2010, 02:35 PM | #18 |
Rep 2,428
09-05-2010, 08:48 PM | #19 |
Rep 164
Drives: 2019 X3 M40i
These runs were pretty much back to back and we only had one small fan in front of the car. We did a few runs and then we let the car cool for 20 minutes and did a few more. It was a dynojet dyno. As he was dynoing the car, there were several times where the car kicked down from 4th to 3rd gear and ruined the run. Not really sure if that affected my runs or not, because the good, full 4th gear runs always took the 3rd or 4th pull to do properly and I assume the car had heat soak by then.
Conditions: 88F with 70% humidity 900 ft ASL 2007 335i E90 Steptronic FBO's CM10 100% VP M1 Meth 93 octane JB3 15-ohm on Map 10 - straight map with defaults Last edited by ktmsmr12; 09-05-2010 at 08:55 PM.. |
09-09-2010, 01:54 PM | #20 |
Rep 55
Bone Stock 93 Octane was about 68 Degrees F outside, didnt feel any humidity outside. (It was an All Wheel DynoJet)
Full Mods, although JB3 was at version 1.4 map 7. (In My Signature below) 93 Octane, same temps as above, but different Dyno (Rear Wheel only DynoJet).
09 E92 335i - Jet Black - M-Tech Full Body Kit - DCT - OEM M-Tech Front CF Splitters -OEM Gloss Black Individual Shadowline Trim - 19" Style 230 Rims (Painted Matte Jet Anthracite)- CF Mirror Covers - OEM M3 Trunk Lip Wing. MODS - JB3 2.0 - BMS DCI - AR Design OC - Helix FMIC - Stett CP - Forge DV's - MS 3" Coated DP's - SuperSprint Catback
10-21-2010, 12:25 PM | #21 |
Rep 25
Modified PAW Motorsport 135i Flashed for 93octane w/upgrades:
http://www.e90post.com/forums/attach...1&d=1287680853
10-25-2010, 10:16 AM | #22 |
Does not play well with others
80
Rep 1,787
Dinan Stage 3 with intercooler and larger oil cooler. Also shows with stock software(dotted line).
(The people at Dinan weren't completely happy with these numbers and we are working on it. They feelit should be able to get 20% more HP)
