06-28-2017, 08:30 AM | #89 | |
salty cowboys fan
6211
Rep 3,425
06-28-2017, 08:54 AM | #90 |
Rep 139
06-28-2017, 11:13 AM | #91 |
Rep 16
06-28-2017, 11:35 AM | #92 | |
Rep 161
I am sure you have heard the term E = mc^2. In the most basic terms, it means that mass and energy are interchangeable when figuring kinetic energy. Add either weight or speed to a car and the forces intended to break the coefficient of friction of the tire to the road in a lateral movement increase. SO yes, weight is a huge factor is what the tires are able to handle before friction is gone and the tire slips. Obviously is the tire compounds and designs are the same, the increased tire contact patch increases traction. But there are also drawbacks to a larger contact patch. Mainly friction and weight. If you don't want to believe weight is a factor in how a tire needs to perform, that is fine. I'll stick to know it and use it to my advantage. Good luck. |
06-28-2017, 02:26 PM | #93 | |
Rep 1,158
Understand that weight has nothing to do with determining what size tires you need for a racing/sports/hyper/powerful car. Look at the tires that hyper cars have, why do you think they have those big tires. Because of the power the car makes. How do they make the a stay planted to the ground when it reaches higher speeds? By adding extra down force by winglets, splitters or a wing. That way the wind will push down on the car to add weight so the car will be firmly planted to the ground. You know, that cool. Go drive a P1 with 255mm tires all around and see what happens when you go full throttle or race it around a track. Since it does weigh so little. F1 cars also up'd they're tire size for this season from 325mm rears to the 405mm rears while uping the fronts from 245mm to 305mm for the 2017 season. The car is wider too. Body and chassis. I don't see where you said "so without power we are talking no acceleration" comment anywhere. Now if you're talking about straight line accel, weight still isn't an concern. It's still about the power. As I mentioned before, you want to put the power to the ground as efficiently as possible and we'll assume you're suspension/drivetrain is already setup properly. So now choose a proper sized tire for the power you're making. Would you want a 245mm rear tire when you're pushing 650rwhp since you're car only weighs 3100lbs? No. You'd want start with a 275mm tire and then try a different tire if you spin too much. You'll actually be surprised at how many cars run 275s while making 600+rwhp and weigh over 3600lbs. Though they may be on barely street legal tires or actually slicks. Like 2nd gen CTS-V's, 03-04 Cobras, GT500s, Hellcats, etc. |
06-28-2017, 02:56 PM | #94 |
Rep 161
The fact you can't even imagine weight being a factor in how a car performs, or it's equipment requirements, tells me I should just stop and leave this alone. It's not worth arguing with you if you are not open minded or wanting to learn.
But since you mentioned 650 hp cars with a 275 width tire I'll give you a little background on me. About 6-8 years ago I had a full blown street car that made 950-1,100 hp to the tire. It was just shy of 4000 lbs. with me in the car. With the wrong converter in the car, I still managed to run 1.32 60' times on 17" street wheels all the way around and a 255 width contact patch tire. I can tell you weight was a huge reason I could get the car to hook so well. You can apply a lot of downward force with all that weight. I won't even get started on the MX235 drag class that my buddies run. They are limited to a 235 width tire yet run mid 4's at 150+ mph in the 1/8th. Some are obviously able to do more with less. I'm not a newb to drag racing and road racing. But I am always learning from testing and talking to others. Anyways, good luck with your beliefs. |
06-28-2017, 03:29 PM | #96 |
Rep 161
Exactly. Faster drag cars use aero and downforce as well. The wings out back help keep the car & tires planted at speed. And Aero keeps the air from under the car as to not have the air under the car lift the car. No one likes taking off on a drag pass. haha
So drag car use aero just as road course cars do. |
06-28-2017, 08:51 PM | #97 | |
Rep 1,158
06-29-2017, 12:09 PM | #99 |
Rep 1,158
Alright so. Look at this. You first say weight is the reason why the Camaro needs the wide tires. What you're saying is that any heavy vehicles needs wide tires because it weighs so much. Not because of the power it's making.
That means a 10000 hp top fuel car doesn't need the tire setup it currently has. They should be using a smaller tire since it weighs so little. This is the assumption I get that YOU are saying. |
06-29-2017, 12:30 PM | #100 |
Rep 161
I said the power and weight are part of it. YOU said weight has nothing to do with it.
You don't get the points made, you don't understand it the physics involved, and make assumptions that are not correct. I am done addressing it. |
06-29-2017, 02:03 PM | #101 |
Rep 1,850
Power, weight, grip, and to a lesser extent drag, make a laptime. Handling is optional, although I bet this car probably handles pretty well.
Re: the discussion above, the reason the car uses really fat tires is because for a given weight and power level, that allows them to use a softer compound without destroying it. You could use 2 inch wide tires made from the same compound, and they would have a very similar grip until the point they overheat / the car tears them apart which would probably happen immediately. |
06-29-2017, 02:24 PM | #102 | |
Rep 1,158
You never said power anything about power. You've only talked about weight. I say power has a big part of it and weight is never the factor for choosing a tire size. You obviously are set in your ways so I'll continue choosing tires for the power they are making and the amount of grip I want for handling while you can choose tires solely for their weight. |
06-29-2017, 06:54 PM | #105 |
NOOB
1603
Rep 1,356
Motortrend and a bunch of other media guys came to my local track (Area27) to test the ZL1 1LE and it kicked fucking ass.
Randy was able to pull off a 2:11.88 on this monster track and for reference, the official time set by a 675LT was 2:10.40 and an ACR did it in 2:09, bone stock, both driven by professional race car drivers. GT3 RS's have posted 2:13s and the fastest Radical has just broken 2 minutes. http://www.motortrend.com/cars/chevr...t-test-review/ For just about $73k usd, this thing is definitely the best bang for the buck. I have so much respect for this machine and its value. Last edited by Nkc; 06-30-2017 at 12:12 AM.. |
Red Bread4465.00 Mr Carrots766.50 |
06-30-2017, 04:42 PM | #107 | |
Rep 1,850
86 and Vig must have missed the part where I accurately distilled track performance down to as few criteria as possible AND explained wide tires in a way that hopefully makes sense. See my previous post, and if you have any questions, we can have an intelligent adult discussion about it. ��
*This is because coefficient of friction will increase the less loaded a given piece of rubber is, but to really take advantage of this, you either need tires with an impractically big contact area, OR a really light vehicle. Last edited by The Wind Breezes; 06-30-2017 at 04:54 PM.. |
08-30-2017, 09:00 PM | #109 | |
Rep 880
Drives: 2011 E90 M3, 2019 F150
Full disclosure. I work for an American auto company. |
swanson738.00 HawkeyeGeoff263.00 |
08-31-2017, 08:35 AM | #110 | |
Rep 620
Drives: E90 335XI MSport, S2000
swanson738.00 |
