      10-27-2021, 10:25 PM   #23
g11hoonigan
Drives: BMW 740i
Who runs their 7er off-road? I mean you CAN but SHOULD you?
      10-28-2021, 03:06 PM   #24
Shantosh Seewooruttun
Drives: Sleek
Originally Posted by LuckyW View Post
Let me know how it works in off-road conditions
LuckyW, you are not taking something there, are you?
      10-29-2021, 08:47 AM   #25
LuckyW
LuckyW's Avatar
86
Drives: BMW 520d M Sport
Not me, not ... But everyone who does not see the difference should only take half or change the dealer.
      10-29-2021, 11:10 AM   #26
Qsilver7
Qsilver7's Avatar
...everyone who does not see the difference ...
I do see a difference...but is it due to the wheel/tires...or simply a difference due to the M-suspension versus a base/standard suspension?
  • top pic is sporting an M-emblem...does it also have some suspension tid bits from the M parts bin?
  • bottom pic is NOT an M model
When was the 2nd pic taken? If the wheel/tire was just mounted and the car was lowered and not driven before the pic was taken...the suspension is not had a chance to articulate to its normal resting location.
And the pics dont' give us the actual specs of the wheels/tires mounted to each vehicle. One has BMW stock wheels...the other has aftermarket wheels. What size tires are mounted to each of these two sets of wheels? Does the BMW mounted with aftermarket wheels have the correct +one/-one tire size mounted...or did they choose to go with a different tire size that is greater than the recommended +one/-one size?
      10-29-2021, 01:37 PM   #27
Drives: Sleek
The comparison is improper here because the two cars are likely to be different - one is likely a M760 and the other a 750 M-Sport. Those two have different specifications. Then comes to the wheels themselves, one is OEM with recommended tires while the other is aftermarket. My point is that if they were the same models and the only difference were the rims say were 19 and 21 inches (but OEM and with recommended tires), then both the ride height and gap between the wheel and the arc should be the same.
      10-29-2021, 01:43 PM   #28
Atomsplitter
Drives: 2017 G11 750; 2010 E90 328
The outside diameter of the tire is exactly the same as the 20" OEM that it replaced. The space between the fender arch and the tire is exactly the same as it was prior to replacement. The car rides and handles exactly the same as it did.
In the end, i replaced the oem wheels and tires with wheels and tires that are functionally equivalent. The tires are an oem option on this car. The car does not look at the wheel and change suspension. All that matters is the outside dimension of the tire. In function, nothing is different. I'm happy with it. I have no concerns.
      10-31-2021, 12:38 PM   #29
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Does look quite high, took this picture of mine today
730d/Z4C
      10-31-2021, 12:39 PM   #30
paul.j.ghosh
Drives: 2019 M760i xDrive
Start the car - it will go up.
      10-31-2021, 12:54 PM   #31
LuckyW
LuckyW's Avatar
86
Awesome,
      10-31-2021, 06:03 PM   #32
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Engine was on
730d/Z4C
