06-22-2016, 11:29 PM | #1 |
Rep 308
Vehicle storage?
Looking for a car storage for my F30 for 6 months.
Is it necessary that i get an indoor storage with climate control? The ones i found are all outdoor storage with individual garages. Only Simply Storage have 10x20 for under $90. Also, do i need to put some thing in the fuel tank to prevent the gasoline from deteriorate or something like that? I guess as far as batteries go, i need to disconnect both the front and rear batteries. Let me know what you guys think
F30 328i sedan
06-23-2016, 09:51 AM | #2 | |
Rep 2,665
Fuel stabilizer will help some but I question how much it helps the ethanol part of most fuel, I would prefer to store it with non ethanol gas and stabilizer but haven't been able to find non ethanol around here. Front and rear batteries? What car has two batteries? Best case would be to either put a Battery Tender on it while in storage or remove the battery and store it with the Tender on it.
06-23-2016, 11:19 AM | #4 | |
Rep 308
I know there is one in the trunk for sure. |
06-23-2016, 11:20 AM | #5 |
Rep 308
I was actually told that fillin up the gas full with prevent the water to coming in. Would adding the stabilizer still be a better option than full gas tank?
06-23-2016, 12:10 PM | #6 | |
Rep 876
That is good advice to fill up but I would do both. Filling up decreases the surface area for water to collect but doesn't eliminate it. Let the stabilizer run through the fuel system for a few minutes before storage. |
06-23-2016, 03:31 PM | #7 |
Rep 249
No you won't need climate control. It's not critical you get a fuel stabilizer given your car's newness, and length of storage. Overfill your tires to avoid flatspotting. Either put the car on a trickle charger, or leave it with the negative battery terminal disconnected.
2008 SS E90 M3 6MT. Alex@Alpine Stage 2 tune, RPI X pipe, HRE 540, MFactory Dry Carbon DS, Swift Springs, Ultimate Clutch Pedal, Do88 Engine Oil Cooler, TMS Subframe Bushings, TMS Delrin Diff Bushings
06-23-2016, 03:36 PM | #8 | |
Rep 6,196
Climate controlled will prevent the brakes from rusting, and to a lesser degree, anything else on the car. Take this from a Canadian that has stored cars over the winter dozens of times. Last edited by MightyMouseTech; 06-23-2016 at 03:45 PM.. |
06-24-2016, 11:35 PM | #9 | |
Rep 308
Is there a difference between ethanol neutralizer and fuel stabiliser? It seems like Sta-Bilhas some known products or Amsoil
F30 328i sedan
06-25-2016, 06:27 AM | #10 | |
Rep 18,691
Yes you should add fuel stabilizer in the correct amount for a 16-gallon tank and run the engine for several minutes to get the treated fuel run through the entire fuel system. Store the car with a full tank of gas. Do not use a "trickle charger" because it will over charge the battery. Use a "battery maintainer", which is not a trickle charger (people confuse the terms). Max pressure in the tires is a good idea. I also recommend a mothball or two in a glass cup in the interior to keep critters away. Stuff rags in the intake snout and exhaust tips to keep mice from building nests in the exhaust and air box.
Preformman1.50 |
06-25-2016, 06:36 AM | #11 | |
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
06-25-2016, 07:23 AM | #12 |
Rep 18,691
The reason to fill the fuel tank full is to minimize the the free air space in the tank. Reducing the air space minimizes the amount of water vapor that is in the air in the tank that comes out of the air and forms water though condensation. Condensation occurs from the changing temperature of the fuel in the tank. This really isn't an issue since most gasoline has ethanol (alcohol) in it, which absorbs any water in the fuel.
06-26-2016, 01:51 AM | #13 |
Rep 308
Thanks for the tips guys. I will be putting in Sta-Bil product as well as de-moisturizer inside the car with windows cracked open.
Off topic: is it ok to storage butane gas and butane lighter in the storage for months? (not sure how the temp. would be in the storage)
F30 328i sedan
06-27-2016, 01:26 PM | #14 | |
Rep 18,691
06-30-2016, 10:03 PM | #15 |
Rep 308
Oh ok. I just thought that closing the window would put some stress against the rubber trim where it seals the window
F30 328i sedan
06-30-2016, 10:06 PM | #16 |
11817
Rep 23,187
Here you go. I use e0 in my track car and this is how I find it.
http://www.pure-gas.org/index.jsp?stateprov=MI |
07-01-2016, 12:52 AM | #17 | |
Rep 308
even unbranded company? I should make a printout of this
F30 328i sedan
07-03-2016, 04:17 PM | #18 |
Rep 238
Drives: '16 M4
I plan to store my M4 for the winter. And by 'store', I basically mean not drive it from about November/December through March/April so I find this thread very helpful and plan to take a lot of the advice given.
One thing I'm concerned about and haven't seen mentioned is what surface the tires should and shouldn't touch. My garage floor is bare concrete. I seem to remember being told once that bare concrete for extended winter periods is a no-no and therefore you should place _______ under each tire. Anyone care to fill in the blank? I believe cardboard is also a no-no but I seem to remember carpet being OK. I also seem to remember rubber not being a good choice. |
07-03-2016, 04:42 PM | #19 | |
Rep 308
Also, i just found out that if you are financing your vehicle, then you must keep your insurance even when it is in the storage. I have Farmers insurance. I gotta figure out a way to pay less than $50 a month or none while it's being stored.
F30 328i sedan
07-03-2016, 08:40 PM | #20 | |
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
07-05-2016, 09:35 AM | #21 |
Rep 2,665
Unless you are covering the whole (or at least most of) the garage with a material that stops moist air I can't see small mats under the tires changing how much the humidity is in the air and reaching your car.
Basically the same as standing on a plastic mat and hoping you feel better because of the reduced humidity that is getting to you.
07-05-2016, 09:43 AM | #22 |
Rep 1,986
Humidity penetrates through the concrete and hit underneath the car where rust usually starts. I've heard people use roofing tar paper to do the same. My Miata is a 90 with no spec of rust due to this practice. I also happen to think PVC mats look awesome in the garage. Btw my garage is heated...
Preformman1.50 |
