04-28-2016, 09:16 PM | #23 |
Rep 263
Congrats. I have a 2004 Mazdaspeed Miata that is modified to 300hp that I love surprising people with on the track. Definitely a fun sleeper.
04-28-2016, 09:18 PM | #24 | |
Rep 1,850
Rev match.
Like I said, if you're a quick learner you'll probably be OK. Don't try it until you've got a solid grasp on what kind of RPM adjustment (rev match) is needed for each shift. I've clutchless shifted a ton of cars including the one I've had since new for 80K and it wasn't a problem. If you're not under pressure and you get a lot of practice you'll be able to learn the basics for all this in the first couple days if you're reasonably athletic and practice a lot. |
04-28-2016, 09:28 PM | #25 |
Rep 470
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
04-28-2016, 10:00 PM | #26 | |||
Rep 318
04-28-2016, 10:10 PM | #27 | |
Rep 263
The wheels are the stock 17" Racing Hart wheels that were standard on the 2004 Mazdaspeed. On the track, I use 15x8 wheels with sticky rubber for better grip and less unsprung weight.
04-28-2016, 10:32 PM | #28 |
Rep 318
Your track wheels look great too! The 17s seem like they do add a lot of weight to the Miata, being that its so small. Looks good though!
04-29-2016, 05:58 AM | #29 |
Rep 268
The miata has a very light clutch, and the take up point is mid stroke: as stated above you don't have to rev a lot to shift one. Its pretty easy to pick up fast.
Clutchless shifting is not something one needs to ever do unless you completely lose the slave cylinder and need to limp home: I would not spend much time on this, just look for signs of failing slave (harder to get into gear): they can fail on the miata, its a $60 part easy to swap out in < 1 hr. Don't go mod crazy for a while. Best things to do: 1. Find a good alignment shop (miata are low to the ground, some shops don't have gear for cars that low) that will align to your spec and bring an aggressive 'Lanny' alignment or similar. $200 or perhaps less 2. Tires tires tires 3. If you get bitten by the miata bug, the stock shocks if not Bilstein are slowly dying, think of some Koni's 4. Drive drive drive Slamming them, stiff springs what have you really can upset the fine balance of the car stock. Yes it has some lean, but that is by design...suckers will grip just fine with the right alignment and tires. To do lowering right, you have to also have enough travel and replace more parts then just springs and shocks (Flyin' Miata catalog is a great shopping tool, but will hurt your wallet a tad: my recommended shop however Enjoy the drive, - b |
04-29-2016, 06:38 AM | #30 | |
Rep 318
04-30-2016, 04:47 PM | #31 |
Rep 2,476
Drives: Satan's Chariot 2.0
05-01-2016, 08:06 AM | #32 |
Rep 318
Picked it up yesterday...and did so without stalling! I was surprised. I'm still a little jerky when it comes to driving stick, so I've got to practice that. Overall, I really like this car! I can't say too much about it yet since I haven't had it long, but I have a feeling I'm going to have good fun with this car. Browsing around on the Miata forums, I'm learning a lot about it.
05-01-2016, 08:25 AM | #33 |
Rep 248
Congrats! Been thinking of getting an NB Miata as well for road racing and doing the Honda K series swap for the ultimate bang for buck.
07 328it
05-01-2016, 08:57 PM | #34 | |
Rep 318
05-01-2016, 10:18 PM | #35 |
Rep 445
Drives: BMW
Garage List 2017 Range Rover Sp ... [0.00]
2014 McLaren MP4-12C [0.00] 2016 Dodge SRT Viper [0.00] 2012 BMW 640i F13 [0.00] 2015 Nissan Patrol Y62 [0.00] |
Congratulations! Can't go wrong with a manual roadster. Hope you have lots of fun with it. #LongLiveTheManual
05-01-2016, 10:23 PM | #36 |
Rep 318
05-02-2016, 05:37 PM | #37 | |
Rep 14,108
Drives: G82 M4C X-Drive
The OP is learning to drive manual and you are trying to teach him heel/toe and clutchless shifting? OP: Learn the basics. Don't even THINK about heel/toe or clutchless shifting, or coasting in neutral. You gotta walk before you can parkour.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-02-2016, 07:51 PM | #38 | |
Rep 318
05-02-2016, 07:56 PM | #39 | |
Rep 1,850
As far as rev matching and heel toe, these ARE the basics--I was doing them literally as soon as I could get the car moving without stalling. This is the best way to learn--learn the right things first, step fully into good habits, and you'll be way ahead of everybody. Clutchless is more controversial since you could possibly damage your transmission, but again, I found it easy and was doing it within my first few hours of driving stick and my tranny lived to tell the tale. |
05-03-2016, 12:04 PM | #40 |
Rep 3,030
Go buy a 70's Alfa, specifically a 116 model like an Alfetta. Drive it for a day, sell it, then jump back in the Miata.
You'll be a brilliant shifter in 24 hours, you have to be or you're not gonna move the Alfa. |
05-04-2016, 11:29 AM | #41 |
Rep 2,476
If anyone knows of any running & driving Miatas under $3k for sale, let me know.
05-04-2016, 11:47 AM | #42 |
Rep 382
I've built 2-3 different miatas. Craiglist will have a na body style for 3k or less no prob.. My last Miata only had 80k miles and it was a 96 1.8. Most fun car you can buy for under 10k imo. Teaches you great car control and easy to maintain. I Picked mine up for $1,900 ! As for clutch less shifting, you are right. Horrible idea to try as new driver and completely pointless at this stage. focus on basics, heal toeing, match reving , ect . Congrats to the OP!
05-04-2016, 12:48 PM | #43 | |
Rep 2,476
05-04-2016, 02:40 PM | #44 |
Rep 382
