12-27-2017, 10:27 AM | #45 |
#buildnotbought
10866
Rep 4,895
But afaik he didnt design the V6 from the dino 206/246
12-27-2017, 10:39 AM | #46 |
Rep 9,160
As far as I can tell, no, he didn't design the 196 engine, but he was responsible for converting it to road duty. The Fiat Dino engine and the 206GT are identical, even though there was a claimed hp difference. Apparently they were directly grabbed off the Fiat production line and installed with no modifications.
12-27-2017, 12:20 PM | #47 |
#buildnotbought
10866
Rep 4,895
Yes that engine is a design from Dino himself (and Jano).
But it sounded strange to call an engine a lampredi engine when he didnt design it and only adapted it to a less powerful spec, certainly in regard to that he did design multiple engines. When people talk about the 'Lampredi engine' they usually refer to his twincam I4 that was used over 30 years. Its like talking about a busso and referring to a 50's F1 v12 engine. (and bringing up Busso: what an engine, probably the most beautiful v6 to look at from the modern era! Sounds really good too)
12-28-2017, 08:19 PM | #48 |
Rep 316
Drives: C63S Sedan|350Z
^^^this I agree with The V-6 car I have does not have a viscous coupling between the motor and the rest of the drivetrain so I can feel the individual firing pulses as I take it to 8200rpm (feels kinda gritty past 5k although it makes power to 7500rpm). The N55 feels turbine smooth by comparison. Also the V-6 car has a decent set of multilinks up front with the majority of the drivetrain behind the front wheels. This wouldn’t be possible with an I-6. |
12-29-2017, 01:58 AM | #50 |
Rep 316
With any 6MT VQ35 or VQ37 you can feel it through the shifter at idle & at highrpm because of how the shifter is configured. That was one of the main criticisms of that powertrain.
C63S Sedan: Long Live The V8
350Z: The Very Poorman's 981 GT4 |
01-01-2018, 12:13 PM | #51 | |
Libertarian
71934
Rep 4,035
I'm gonna assume some of you haven't driven a R35 GT-R. |
01-01-2018, 10:26 PM | #52 |
Rep 1,370
Meh. Had a e92 335i N55 for years and now have an Audi SQ5 with the new V6T. It's just as buttery smooth and has a very similar power band, with the V6T having a slightly better top end.
Had a VQ35HR in my 350z years ago and that motor was like a vibrating blender when revved up (but was a solid engine otherwise). But that's a thing of the past. Now you got those two MotorTrend reviewers making comments on how the V6TT in the Alfa QV feels smoother compared to the M3. And you've got Chris Harris saying the V6TT in the QV has a more linear power delivery compared to the M3. Not a fanboy of any car make here. But it's funny to see you BMW fanboys over-analyze stuff and come to conclusions that don't align with reality at all. Now you have Cadillacs that handle dynamically superior to BMW's and Alfa's with better powertrains. lulz |
01-02-2018, 11:10 AM | #53 |
Rep 316
I have lots of experience with the R35 GTR. Ideal engine placement & excellent driving dynamics but a little too 'clinical' for me.
01-02-2018, 12:17 PM | #54 |
Rep 14,519
Drives: Audi S3....don't judge me
I always thought there was a torque advantage to the I-6, all other things being equal.
01-02-2018, 01:37 PM | #55 | |
#buildnotbought
10866
Rep 4,895
But as especially bmw engine have a fairly long throw, they usually do give more torque than their v6 competitors that usually have an oversquared setup, especially in the lower rpm's (This goes mainly for NA).
01-02-2018, 02:27 PM | #56 |
Rep 105
For packaging and displacement size, and crank rigidity, the V6 is going to be the ticket. Big displacement cylinders can't be lined up in a row without considerable length on top of a long block.
I6 is the way to go for driving experience (buttery smooth, inherently balanced), but crank length becomes a weak point at high power levels, and it requires a long front end, and placement can effect chassis dynamics. Someone mentioned the Flat 6, which is great for chassis balance, and packaging but they still suffer from balance issues like opposed V engines do and they usually have oiling issues because, you know, gravity. This was a big problem on old airplane motors. Porsche has done really well with them, but Subaru is notorious for having ringland issues. |
01-02-2018, 03:18 PM | #57 | |
#buildnotbought
10866
Rep 4,895
Remember, we're lining the i6 up to a v6, NOT a v12 (or a V8 for that matter) Also crank rigidity isnt really a problem, as there are loads of v12's around, with way more force on the crank. Look at how long cranks can get if you look at shipbuilding. The key issue is using enough crank bearings. Other than that there is absolutely no reason why an I6 crank would be weaker than a v6 crank (certainly not with all the various split pin v6 cranks around) Oiling issues only come down on using an inadequate oilpump, too small oil passages and such. I mean serving 2 banks on a v6 isnt an issue either is it?
01-02-2018, 06:28 PM | #58 |
Libertarian
71934
Rep 4,035
01-02-2018, 06:52 PM | #59 |
Rep 316
01-02-2018, 07:02 PM | #60 | |
Libertarian
71934
Rep 4,035
The number #1 type of engine in general aviation today is the horizontally opposed engine, Lycoming, Continental etc mainly because of reliability. Most Inline6 M engines BMW designed have rod bearings issues, so. |
01-02-2018, 09:50 PM | #61 |
Rep 18,742
I have a 18 year old Honda F6 Valkyrie Interstate 68,000 miles. Runs like a top. It's all in the engineering.
The Choosey begger71933.50 |
01-02-2018, 09:57 PM | #62 | |
Rep 18,742
01-03-2018, 07:35 PM | #63 |
Rep 654
Hmm....
All this talk about 6 cylinder engines...........yet no mention of the VR6. Anyways: Rumors are that Volkswagen is working on a 400 HP version of this engine in one its Arteon prototypes (for a possible "R" performance version). According to Mr. Martin Hube (product-line spokeman at Volkswagen), they said that their prototype with a new VR6 engine is currently undergoing evaluation. |
01-03-2018, 08:08 PM | #64 |
Rep 3,408
The first car I ever drove was a '48 Pontiac with a straight 8. I'll bet a few on this forum ever heard of this configuration since straight 8's have not been around since the 1950's. Since I was curious, I Googled it and found out that in the 50's Mercedes put a straight 8 in a formula one car and in the 300SL. Our family '48 Pontiac was a hell of a car with "3 on the tree" and enough room in the back seat for......whatever. The good old days. Last edited by sygazelle; 01-03-2018 at 08:15 PM.. |
Efthreeoh17318.00 |
01-03-2018, 09:36 PM | #65 | |
Rep 9,160
[IMG]https://www.mdiecast.com/pictures/_u...639_M-076d.jpg[/IMG] Oops, make that drums. Got ahead of myself. [IMG]https://www.supercars.net/blog/wp-co...SLR-5-1024.jpg[/IMG] |
sygazelle11426.50 |
01-03-2018, 09:42 PM | #66 | |
Rep 1,148
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone) |
