01-15-2018, 09:29 PM | #155 |
Curmudgeon and Pedant
690
Rep 3,489
01-16-2018, 11:14 AM | #157 |
690
Rep 3,489
01-17-2018, 09:15 AM | #158 |
Rep 407
Those here that seemingly don't want to acknowledge that what MB has done to the I6 which could result in a resurgence across manufacturers, not just BMW and BMW alone.
All the greats of the I6 world could start using them again as it matches well with I4 production. |
01-17-2018, 09:59 AM | #159 | |
Rep 9,160
01-17-2018, 12:38 PM | #160 | |
Rep 43
He did point out the one plus with the design though, the supercharged V8 will bolt straight in to anything that uses the V6. |
01-17-2018, 03:19 PM | #161 |
Rep 14
i had a straight 6 in my cherokee and even though it had a couple problems (probably due to the torture i put it through) it would be extremely easy and quick to fix. about to buy another cherokee!
01-18-2018, 07:33 PM | #163 | |
Rep 316
Drives: C63S Sedan|350Z
Most 90 degree v-6’s are v-8’s with two cylinders chopped off. |
01-19-2018, 05:58 AM | #164 |
Libertarian
71934
Rep 4,035
For the ill informed, today's twin turbo V6's like in the R35 GT-R are just as smooth, just as torquey and just as reliable as any inline 6.
The advantages of a V6 Shorter than even an inline 4, moves the CG/ weight further back, improving handling! Engine is not installed leaning to the right because it's too tall, also the V6 has a lower CG. |
01-19-2018, 01:19 PM | #166 |
Rep 9,160
01-19-2018, 03:01 PM | #167 |
Libertarian
71934
Rep 4,035
You're pretty ignorant if you think a modern V6 engine is not balanced, it's a more complex design and require more engineering but they're balanced and just as smooth and balanced as any inline 6.
01-19-2018, 03:06 PM | #168 |
Libertarian
71934
Rep 4,035
From wiki
60° V6 is compact in length, width and height, which is advantageous for rigidity and weight. The short crankshaft length mitigates the torsional vibration problem, and secondary balance is better than in an inline 6 because there is no piston pair that move together. |
01-19-2018, 03:11 PM | #169 | |
Rep 9,160
You can add balance shafts to make it imitate a balanced engine. And some are nicely done, the GTR lump being a little better than average. The VQ being perhaps the worst recent example, and the original NSX being perhaps the nicest. Compare any two motors of similar displacement, under/over square design, with similar drivetrain layout, and similar boost, and the V6 will not rev as quickly, will not be naturally balanced and will generally not sound as good. Please note that BMW has found incredible ways to screw up the traditional half a V12 sonic signature of the I6. There's a reason I'd love a G34 GTR but have no love for the G35. Only part of it is the transmission. Your last post is comparing secondary balance, while the entire content of this discussion has been about primary balance. And for the love of all things holy, stop talking about packaging. I6's will be smoother, V6's will be easier to package. |
01-19-2018, 03:23 PM | #171 | ||
Libertarian
71934
Rep 4,035
You showed your ignorance, even an inline six is not naturally balanced, Quote:
Naturally balanced or not, balanced is balanced! |
01-19-2018, 07:16 PM | #172 |
Rep 43
Maybe, but the Jaguar V6 block keeps the same dimensions as the V8 block, the two unused cylinders aren't chopped off more just blanked off (i suspect the cylinders are actually positioned different but its still a V8 sized block)
01-19-2018, 08:53 PM | #173 |
Rep 421
timing chain mechanism moved to the back of the new engine for weight transfer and the fact that the flywheel and transmission mass "stabilizes" the back of the engine better than the front.......and would assume less vibration and distortion on the timing chain mechanism moving it to the back. Longer life?...less long term problems??.....who knows
01-21-2018, 11:04 AM | #174 | |
#buildnotbought
10866
Rep 4,895
https://en.wikipedia.org/wiki/V6_eng...and_smoothness
01-22-2018, 05:27 PM | #175 |
Rep 316
I kinda think a lot of you are confusing even firing with engine balance.
C63S Sedan: Long Live The V8
350Z: The Very Poorman's 981 GT4 |
01-28-2018, 01:04 PM | #176 |
Rep 18,742
Back in the day, my dad had a Johnson 125 V4 2-stroke on his boat. Cool motor I always thought...
