      07-19-2021, 03:11 PM   #177
E92TTCoupe
Drives: x335i/x550i/x640i/x540i/c750i
Originally Posted by 13M5F10 View Post
I'll see if I can grab my measurements. I'm back at stock height.
Thanks bud!
      07-25-2021, 04:05 PM   #178
kasrar
kasrar's Avatar
Drives: 2016 BMW 750i M-Sport
Originally Posted by E92TTCoupe View Post
Thanks bud!
Hey, lowered my G11 today using ISTA+ and my stock height measurements in sport were as follows:
26.5 inches Front (673mm)
26 inches Rear (660mm)
Hope that helps!
Also, I lowered my G11 by 30mm in the front and 25mm in the rear, thinking it might be too much since on my test drive I found that it was far less comfortable, does anyone know if its possible to lower the sport and comfort driving modes separately? I'd like to keep comfort and comfort plus at stock ride height but sport lowered if possible.
      07-26-2021, 04:01 PM   #179
E92TTCoupe
Hope that helps!
I truly appreciate that, thank you.
      07-29-2021, 05:02 PM   #180
KOT666
Drives: G11 740xd
Originally Posted by LuckyW View Post
Measuring the lower edge of the rim with the upper edge of the wheel arch, we give the measure in millimeters.
68cm equals 680mm + the value by which we want the car to lower 20mm = 700mm
According to your preferences and needs
it's possible to lower only sport mode ? and keep comfort mode stock ?
and if yes, how to ?
      07-29-2021, 05:49 PM   #181
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
@mrgicm might know the answer.
      07-30-2021, 12:47 PM   #182
LuckyW
LuckyW's Avatar
86
Drives: BMW 520d M Sport
No is not possible to do so ...
      07-30-2021, 02:52 PM   #183
LuckyW
LuckyW's Avatar
86
How do you return the car back to stock via software? I want to raise it up back to OEM. What would be the mms?
Measure the current height 4 wheels follow ista requests exactly and bring it to ista without adding or subtracting, the suspension will be set to OEM
      08-10-2021, 04:13 PM   #184
MTornberg
Drives: BMW G11 LCI 740 d M-Sport xD
But somewhere hiding in the coding is a value to tell the car how to react when sport mode is engaged. My car lowers itself with approximately 10mm when sport mode is engaged. It would be so frickin' awesome to change that value to 20mm lowering instead. Or whatever value it needs to lower a little extra in sport since the function is already there.
      08-18-2021, 02:24 PM   #185
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Not lowering but I wonder about the whether M760li has firmer damper/air spring settings and whether you could code it to a normal 7 if if the hardware is shared?
730d/Z4C
      08-18-2021, 03:32 PM   #186
mrgicm
mrgicm's Avatar
441
Drives: BMW M
M760i has different suspension that is slightly higher when you you compare it (shock absorber next to the other). I have mounted the 760Li suspension on my car (and coded ofcourse) and the difference is barely noticable to almost none compared to a normal suspension.)
Wills28656.00
      08-18-2021, 03:50 PM   #187
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Thanks for that reply.
730d/Z4C
      12-03-2021, 04:04 PM   #188
turbor87
Drives: bmw 750i, x5
The car can also be remotely lowerd if someone needs. Just laptop with internet and enet cable needed. In this way you keep 100% Original links in case od warranty claims.
Can you do the for G12? Send me a PM
      12-05-2021, 07:25 AM   #189
LuckyW
LuckyW's Avatar
86
You can easily to do this yourself, follow this instruction...
https://www.7post.com/forums/showpos...&postcount=164
      12-05-2021, 08:44 PM   #190
turbor87
Do you have a link to download the software?
      12-06-2021, 12:06 AM   #191
Ilchuck
Drives: BMW 750LiX G12
https://motorcarsoft.com/download/file.php?id=12501
      10-18-2022, 07:14 AM   #192
Force Seven
Drives: 750 li G12
HI
which USB to ODB cable should I buy.
      10-31-2022, 02:32 PM   #193
Force Seven
Drives: 750 li G12
ride height
Hi All
I managed to sort this out with ista and a KDCAN. IF anyone need help with this in the Middle east as I live in Dubai i can help you out.
thanks
Steven
      03-15-2023, 01:06 PM   #194
Strangerstel
Drives: BMW 740e
Hey guys this forum has been such a help. Recently go a 740e and needed to minimise that wheel gap. Was never looking to slam the car, but definitely needed lowering. I went down the road of airmatic drop links as no one around me bar an hour drive dealt with coding. The links definitely were a pain in the ass to get a level ride, but for some reason the mechanic said the stock heights were all over the place to begin with.
Anyway here’s what the final product (having to return twice for readjustments) looks like. I’m very happy with it and can not tell a difference between the stock drive quality. ( worth noting when it was sitting lower than this by error, the car definitely felt worse to drive and quite kitty/unstable on the suspension).
This isn’t a technical measurement but from the top of the rim/alloy to the wheels well is 4 inches all around in sport. 4.5 in comfort.
      03-15-2023, 10:17 PM   #195
M_Bimmer
M_Bimmer's Avatar
583
21" Wheels:
Initially dialed in 26.5" (673mm), but sat too low, so back up at 27.0" (686mm).
      05-15-2023, 12:29 AM   #196
Sneeko
Sneeko's Avatar
Drives: G12 18'
Anyone interested in remotely lowering my 18’ g12 @mrgicm
      05-15-2023, 12:32 AM   #197
Danyal.N55
Danyal.N55's Avatar
Drives: BMW X5 and BMW 7 Series
2017 BMW 740i   [10.00]
Also I believe with the Air Suspension in Spoet Mode at Speeds at 70+ MPH The car will Automatically Lower. But once you slow down anything under 70 it will automatically Raise back up.
Danyal.N55
      05-15-2023, 11:25 AM   #198
Raimo5
Drives: BMW 740d xDrive (G11)
G11/12 will lower to lowest (-10mm) at high speed regime, starting ~140kmh/87mph to unlimited, regardless of driving experience mode selected. It will raise back up to normal driving level when speed falls below ~140kmh/87mph
Toggling Sport mode will lower the car in any driving speed and there is no switchover at high speed regime as car is already at its lowest setting.
