11-24-2017, 11:37 AM | #1 |
Rep 3
Buying a 2006 E46 325ci
Hi All, This is my first post in this forum so please bear with me. I am purchasing a BMW 325ci (2006 model) from a family relative and has 99k miles on it. So I wanted to know what all should I look out for (maintenance wise) at this point.
They've done a PPI, replaced the tie rod end in front engine gasket, drive belt, front brake pads, one tire, and oil seal. Filled up all fluids (oil, brake, transmission and power steering) and did the wheel alignment. This would be my first car, so any help would be appreciated. Thanks in advance |
11-24-2017, 01:14 PM | #2 |
Rep 3,218
Check the rear floor where the subframe bolts to it for tearing. Other than that it's typical E46 stuff. They're very solid cars, good luck with it.
11-24-2017, 01:23 PM | #3 |
Rep 3
11-25-2017, 09:43 AM | #4 |
Rep 3
I found this maintenance schedule from this link https://www.cargurus.com/Cars/Discus...37551_ds515157. What do you guys think about this?
Change oil every 6K miles Change Differential Fluid every 30K miles Replace the following every 30K miles: Water Pump, Thermostat, Thermostat Housing, AC Belt, Alternator Belt, and Idler Pulley Change Radiator coolant every 50K miles Replace Radiator and Expansion Tank at 90K Replace Timing Chain Tensioner at 100K miles Change Brake Fluid every two years |
11-25-2017, 09:57 AM | #5 | |
Rep 450
11-28-2017, 10:33 AM | #6 | |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
Regardless, the cooling system is important. Luckily they are a bit cheaper to replace on an E46 than on an E90.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
11-28-2017, 10:52 AM | #7 |
Rep 138
My son has an 06 325Ci.
Got it with 60k miles last year. Replaced radiator, expansion tank,serpentine belt, new tension pulleys, ignition chamber. Car runs great !!! PS i have a 2017 M240i and I love driving the E46. Hydraulic steering rocks !! |
11-28-2017, 12:29 PM | #8 |
Rep 8,942
I DD an M235 convertible and Dad still has his 2006 330 - with 35k miles on it. Definite +/- to each but actually a very nice pairing.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-29-2017, 02:07 PM | #9 | |
Rep 3,218
good luck with the car, the E46 platform is one of the best BMW ever produced. |
12-06-2017, 09:13 PM | #10 |
Rep 49
^ Agreed. I had my 2000 323i for almost 200k mi. The water pumps with the metal impeller are the only way to go. I would also see if the CVV and hoses have been replaced. They get brittle over time and can cause all sorts of odd error codes. Most things on an E46 are an easy DIY job. Make sure to get a Bentley manual as well
12-06-2017, 09:24 PM | #11 |
Rep 180
I came from an '04 325Ci. The only big ticket items I ever had problems with was the cooling system. I replaced the radiator, WP and t-stat around 80k and sold it with 144k and never had any other issues. It was a relatively low-maintenance car. Man, I miss it.
Might not hurt for a suspension refresh, either. New shocks and bushings will make it feel brand new. |
Tags |
2006, 325ci, used bmw |
