      08-21-2018, 08:00 PM   #1
atorreon
atorreon's Avatar
Drives: BMW 135i
Does anyone out there have a fuse diagram for the box found in the glove compartment on a 2013? Thanks in advance
2015 BMW 750Li
2013 Porsche Panamera
2008 BMW e82 135i
2000 BMW e39 M5
      09-22-2018, 05:36 PM   #2
Qsilver7
Qsilver7's Avatar
If you have the "sheet" (aka fuse index) usually found with/on/near the rear fuse box (see #7 in diagram below) it also contains a layout for the front fuses found near the glovebox.
If you have that laminated sheet...look at it and see if you see any reference to FUSE 1...the glovebox fuses start with fuse #1 and goes to around fuse #60. The fuse box in the trunk goes from around Fuse #60-up.
On my F06, the front fuse index is rectangular and on one end of the sheet found in the trunk...the trunk's fuses are represented on the rest of the sheet and you can see the outline/shape of the rear fuse box that helps tell the difference between the two indexes.
