04-13-2016, 12:29 PM | #67 | |
Plenipotentiary
2614
Rep 3,046
It's all settled now and they'll rapidly improve by leaps and bounds rather quickly. |
04-13-2016, 12:32 PM | #68 | ||
Plenipotentiary
2614
Rep 3,046
The Fresnel Lens on the i3 will also distort the color a bit as well. |
04-13-2016, 12:33 PM | #69 | ||
Plenipotentiary
2614
Rep 3,046
1 full turn is one degree, so start with quarter or half turns. A little goes a long way. The manual adjustments will sometimes make an audible click when moving the stepper motor, sometimes they won't make any noise but are moving the motor, and sometimes there's noise and no movement, or no movement and no noise. Have to pay attention and take it slow. |
04-13-2016, 01:12 PM | #70 |
Rep 280
I had my adaptive LEDs in my F32 re-adjusted right after delivery and with (slightly aggressive coded) EU adaptive high beams I have in my opinion now great light at night.
Especially once high beams are on its impressive Last edited by Ganxxta; 04-13-2016 at 01:23 PM.. |
04-13-2016, 04:21 PM | #71 | |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
Thanks for confirming b/c my M3 literally lights up everything in front of me and I absolutely freaking love it especially since my vision drops below 20/20 at night. I need all the help I can get! |
04-13-2016, 04:28 PM | #72 | ||
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
04-13-2016, 05:57 PM | #73 | |
Rep 701
I would sacrifice some brightness within 10 ft of me to see further and wider any day. |
04-13-2016, 07:56 PM | #74 | |
3498
Rep 3,729
FU DOT and your outdated regs. The ECE standards are far superior. |
04-13-2016, 09:56 PM | #75 | ||
Plenipotentiary
2614
Rep 3,046
Just a passionate enthusiast who specifically switched to an F10 M5 LCI because I really wanted GFHB LED's. Was one of the early coders 2 years ago who thought it was functioning correctly, but didn't have a chance to really experience them until last year. I realized the known methods were NOT enabling full functionality after all on the F10 and have spent the past several months trying to crack the illusive block. In this time, I've learned just about everything there is to know about Solid State Automotive lighting, from the regulations world wide, the workings of every component of every type, read the DOT, SAE, ECE publications front to back, upside down, in multiple languages, acquired data from vehicles around the world, and have even disassembled a number of headlamps to determine what if any hardware changes are present. Have even read the Physiological Studies of how the Human Nervous System reacts the these systems...that really is mind numbing. I'm fortunate to have many contacts and resources in the auto industry available, but it wouldn't be useful and not worth the sacrifice without the Bimmer Enthusiast Communities. The inquisitive minds, and the knowledge contributors are what makes this happen. |
04-13-2016, 09:58 PM | #76 | ||
Plenipotentiary
2614
Rep 3,046
04-14-2016, 08:57 AM | #77 |
Rep 1,472
04-14-2016, 06:39 PM | #78 | |
3498
Rep 3,729
04-14-2016, 07:17 PM | #79 | ||
Plenipotentiary
2614
Rep 3,046
Zero Professional Background in Medicine. I'm a man who wears many hats and works 18+ hrs a day, 7 days a week in a wide variety of areas. |
04-15-2016, 03:50 PM | #82 |
Rep 701
Update:
I did the adjustment last night with the 2 white up facing screws. I thought it was clockwise and realized that it was actually counter clock (up). There was no clicking or any sound. did about 2 full turns. There is a slight increase in height (visibility) but it seems the light on the road also got dimmer (not as white) which i kinda understand why. overall, happy with the result. Still not as good as i would have hoped but with reflectors, i guess this is as good as it gets. unless i go with the high beam coding. |
04-16-2016, 12:51 AM | #83 | |
Plenipotentiary
2614
Rep 3,046
You did do this with the ignition only on, light switch in the on position (not auto), driver's door closed, and waited 80 seconds after closing the door to allow the stepper motor driver to go into diagnostic mode yes? |
04-18-2016, 02:48 PM | #84 | |
Rep 701
I hope i did not do the horizontal adjustment. I did it with ignition on (car off) in auto (when it is leveled), dont remember if the door was closed. Not sure about the diagnostic mode... Tell me i adjusted the right one? |
04-18-2016, 04:07 PM | #85 | ||
Plenipotentiary
2614
Rep 3,046
There are 4 total and those are the horizontal adjusters (which should, but might not have had some plastic plugs in the hex slot). The vertical aim adjustment is not as close to the sealing cap Second problem is they cannot be manually adjusted in auto mode and run the risk of a bad alignment or worse, breaking the stepper motors if they fight against the change. Left Side Lamp shown in image. The vertical is the one closer and clearly shown. |
04-18-2016, 04:33 PM | #86 |
Rep 701
they did not have any plugs in it. But i can tell you that they moved up when i turned them counter clock wise. Or it could be an illusion that the headlight was moving left/right.
Let me see if i can find the other one |
04-18-2016, 04:40 PM | #87 |
Rep 701
i just checked again. The closer white is not visible from outside. Unless there is a hole on the radiator support that i can to reach through otherwise it is not visible. I checked the holes and none of them was connected to it. (my F30 and other HID cars were done that way)
04-18-2016, 05:36 PM | #88 |
Plenipotentiary
2614
Rep 3,046
It just dawned on me...You have standard not Adaptive LED correct? If so then yes there would only be one adjuster per lamp and can ignore my previous reply and image of the Hella Adaptive lamp.
I would suggest however to check the height they're at now with the car on a level surface, and square to a flat vertical reference point and readjust with the switch in the correct position. |
