      05-04-2022, 04:06 AM   #1
donaldj79
Drives: 2004 530i
BAD TRANS or VALVE BODY?? Gotta make a decision!!
Bought a 2010 750Li with 131k miles knowing it has a bad transmission. First car wouldn't even go into gear. No fluid. I had mechanic change all the "mechatronics sleeves and refill with fresh fluid. Car now drives but it kicks you in the butt(on acceleration and deceleration) after a few shifts and goes into limp mode. My question is do I need a transmission or can I get away with just the valve body being rebuilt? I found a transmission I can pick up, but I have to make a decision while it's still available. Posting the Codes below. Bite the bullet on a Used Trans or go the cheaper route and re-do the valve body? Your input and suggestions are appreciated.
CF1701 Message (All) For (EGS_EL,A-CAN, FA-CAN) From (GWS, A-CAN, FA-CAN) is missing
1DB301 EGS, Signal Monitoring (Gear Information) Invalid Signal Content
CF0400 Total malfunction of the CAN-Communication by line interruption
400441 Ratio Monitoring Clutch E implausible
400331 Clutch Monitoring 3-4 implausible
401011 Collision backup measures with Equal Priority
213901 Consumer Readuction: Active
      09-01-2022, 10:55 PM   #2
7'er-addict
Sporty Shorty
7'er-addict's Avatar
28
Implausible codes tell me that the clutches are burnt.
You're needing a new trans.
Clutches are burnt and that is why you are getting that kick in the butt. The TCU is commanding as much pressure as possible to get you in motion.
Apologies for being the bearer of bad news
(edit)
when installing the new or used transmission
RESET ADAPTATIONS! Or else it will do its best to kill itself within the first week of driving until it self learns.
Use ONLY a genuine ZF filter. You can use Mercon SP fluid for a large cost saving. Do Not use any old ATF.
I am being a bit rash in my warnings, but worst case you will burn out the new transmission. Best and admittedly most likely case, it'll drive like @*&# for a week.
      09-04-2022, 06:22 AM   #3
LuckyW
LuckyW's Avatar
86
Drives: BMW 520d M Sport
No drive even for try or test
      01-18-2023, 08:04 PM   #4
nugeesky
Drives: Series 7
got identical issues "fixed"
I got identical problem, problem you can't just buy and replaced. Required to be reprogram for DME to communicated with new one. However, I used E-sys and reprogram or reflash the original software to my EGS, and seem to be a good fixed, Malfunctions never pop up again, and shift normal.
