02-20-2020, 11:33 PM | #23 |
Rep 5
Ok.... gotta catch up with you guys here. Since purchase in the last 3 months I have changed the ignition coils, turbo coolant lines, gas struts for the hood, JB, air filters, ATF + Oil pan change, Diff oil change, thermostat 90C change, two new rear tires.
05-05-2020, 09:04 PM | #24 |
Rep 42
Drives: BMW 750i ///\/\ Sport
22" ACE wheels Cabon Fiber Roof / Kidney Grill / Custom Intake / Accents Lowered By BMW JB 4 stage ll Downpipes ...etc.... Last edited by MrVM7; 05-24-2020 at 05:44 AM.. |
twistedf80m319.00 |
05-11-2020, 11:40 PM | #25 | |
Rep 72
05-15-2020, 01:47 AM | #26 |
Rep 1
Replace the light switch for my 2009 740Li
Do you guys has experience to replace the light switch by yourself? If yes, may I request a brief up for step-by-step replacement? The light switch was melted partially as per the attached picture. I bought a new one from a shop wanna to try replacing it by myself. Thanks in advance!
05-15-2020, 10:27 AM | #27 | |
Rep 7,489
I don't know if you're LHD or RHD...but if you're RHD...the instructions should extrapolate to the right side (if the instructions are for removing the left side trim). Click the following link, type in the last 7 digits of your VIN...then type something like "remove fresh air grille" or "removing and installing/replacing light operating facility" in the search box. You should see a link near the top for removing the left fresh air grille. The instruction to remove the trim that holds the light switch unit should be in those instructions. Also take note of any other links in the instructions that may call for doing some "preliminary" work: https://www.newtis.info/tisv2/a/en/
05-15-2020, 02:50 PM | #28 |
Rep 5
Drives: 2014 740Li xDrive
09-28-2020, 09:37 AM | #30 |
Rep 2,372
I had all coolant lines replaced, rear main seal replaced while it was down for coolant plate leak. Thermostat and radiator hose replaced and also main oil hose replaced because it blew out in driveway. That part alone was 500 bucks and I switched to liquid Molly oil. Time to sell it now after I put over 3k in repairs.Goid thing my BMW mechanic has his own shop at the house .
Formerly Wyndi335I
2009 BMW 750li sold 14 BMW X5 04 BMW X5 11 BMW 335i convertible (sold, sellers market |
