      12-13-2017, 12:08 PM   #1
kutsyy
Drives: bmw
Removing turbos on N63, what should I change in the process?
I am finally ready to replace "turbo oil return housing gasket" on 2010 N63 which is requiring removal of the turbos. Is there anything I should be replacing in the process in addition to the gasket?
Thanks,
Vadim
      08-24-2018, 11:15 AM   #2
jhartmac
Drives: 750I
Was it leaking? and how was this job?
      08-24-2018, 12:24 PM   #3
kutsyy
Drives: bmw
I think it was leaking sine there was oil residual in the valley between cylinders. Job was mostly straight forward following https://www.newtis.info/tisv2/a/en/f...lines/1LfksGKy. Hardest part was to figure out how to remove passenger side catalytic converter cover, other than that, no surprises that I remember (you do need to remove alternator, so you may want to start with it, would make the rest easier to access).
      08-25-2018, 11:07 AM   #4
jhartmac
Drives: 750I
Ok excellent and thank you.
