05-20-2017, 04:40 AM | #45 |
Rep 7
Hello,
For G series, 01 and 10, which chassi code on Esys I need to select? I mean, for old 5 series, F10...I thought that on my Esys and Psdzdata (61.4) will appear G series, but no...something wrong or I need to select any specific chassi on it? Tks |
05-20-2017, 11:14 AM | #46 |
Rep 8,364
S15A psdzdata covers F090/G001/G002/G011/G012/G030/G031/G032/RR11/RR12/RR31
05-24-2017, 07:24 PM | #47 |
Rep 7
05-24-2017, 07:27 PM | #48 | |
Rep 8,364
You need to update Launcher. PSdZ is unmapped and update will make no difference as long as you can "Read Coding Data" without error. |
07-14-2017, 12:43 AM | #50 |
Rep 8,364
Yes. You need at least Nov '16 software on vehicle; though, latest for best performance. Then, it can be coded and add FSC for full functionality.
07-14-2017, 07:03 AM | #51 | |
Rep 213
if you can please share the details on coding and where do i get the FSC code from? Also do you have a cheat sheet for G12 as you have done quite a few code mods? if so please share that as well. Thx. |
07-14-2017, 02:20 PM | #52 | |
Rep 8,364
No Cheat Sheet. I use Launcher Cheat Codes. |
audiogolf39.50 |
10-09-2017, 01:34 PM | #53 |
Rep 206
Hi All,
Can anybody link me, or attach a list of codes with their function? Not sure if they are the same as E-Sys cheat codes. I am currently using "Bimmercode" App, and there are many easy codes built in, but I want to get into expert mode and see what I can really do. The problem is that everything more or less is gibberish, so need to understand what everything means. Thank you in advance! |
10-09-2017, 02:33 PM | #54 | |
Rep 8,364
10-17-2017, 08:12 PM | #55 |
Rep 16
You guys are very technical being able to do it yourself, I ended up using CodeMyCar, extremely pleased with them.
Glad to be able to turn off DRL on Canadian cars. |
10-18-2017, 10:45 AM | #56 |
Rep 676
Drives: 2015 M6 Gran Coupe
I'm still waiting to hear back on how to keep on the Light Carpet on at all times when headlights are on.
02-19-2018, 08:14 AM | #58 |
Rep 835
I don't believe 8TH was an independent option on the 7 like it is on the 5, so not sure if it can be retrofitted on it's own or if it needs to part of the driving assistance options
02-19-2018, 08:22 AM | #59 |
Rep 835
having said that, if you have the relevant equipment already in the car, I don't know if adding 8TH to the VO would enable it but I very much doubt it would be that simple
02-19-2018, 10:30 AM | #60 |
Rep 8,364
02-19-2018, 01:07 PM | #61 |
Rep 646
02-19-2018, 01:43 PM | #62 |
Rep 835
02-19-2018, 05:13 PM | #63 |
Rep 646
Never tried it. Probably nothing much I feel I might want to code though I know you can remove the limiter if you catch the car before it's been running for 10 hours... Might be good for an autobahn run
02-19-2018, 05:32 PM | #64 |
Rep 835
There’s only one thing I want to code I think, which is to keep auto start stop off when I turn it off and restart the car. I hate having to turn it off every time I start the car so I coded that out on my 6
02-23-2018, 06:27 AM | #65 |
Rep 527
Out of curiosity, is it possible to code a June 2016 model 7?
So, for example could one add apple car play and exec drive pro via coding or are there hardware bits needed to achieve this? What can one code on an earlier model? (point me to a relevant list if there is one and I'll educate myself, not lazy just don't know where to start as it where!) Is it possible to bring the iDrive system up to the latest version yet? (so 5 to 6) Thanks for any comments / pointers / advice. Safe travels. |
02-23-2018, 06:30 AM | #66 | |
Rep 835
I haven't got myself up to date with what's able to be coded on the 7 yet fully but CarPlay won't be able to be coded, you need to buy it through the connected drive store. On the 6, iDrive id 5 was able to be coded up to 6, there were hardware differences but I believe it should still work fine. Once I get my 7 I'll be able to give you more information on what's available. I'll see if I can find a list but the lists I saw before were based on US cars which have different things enabled or disabled by default so I'll se what I can find. |
