      03-08-2013, 07:53 AM   #1
DBV
DBV's Avatar
779
Drives: G87 M2, G20 330d, Brabus Smart
2023 BMW M2  [8.75]
2018 Brabus Smart  [0.00]
2021 BMW 330d  [0.00]
F01/F02 Angel Eye Upgrade - Pics
Ok, so after reading seemingly EVERY thread on this topic, I have yet to find a definitive answer to the question of what angel eye bulbs to use for a clean, easy upgrade to the stock bulbs.
It seems like LEDs give the best light, however most throw error codes.
The PIAA route seems most logical for those simply wanting a change without the resistor headache, however it seems that unless you go BLUE, the light stays almost the same color.
Now, deciding on the bulbs shouldn't be so tough, except that there are almost NO pictures of the F01/F02 with upgraded lights out there. There are PLENTY of kits being marketed as being the best. Stand behind your product and show us pictures. I don't care about 5 Series, or 3 Series compatibility and looks. I own a 750i, which has a completely different lighting system.
SO, those of you with Angel Eye upgrades, for the benefit of other 7 owners: PLEASE post pics of your setup, stating what kit you got, and if you've had issues with coding or error messages. Thanks to all!
      03-08-2013, 04:53 PM   #2
335ifanatic
335ifanatic's Avatar
51
Drives: Revuelto, Urus Performante, X5
Nope, nothing on the market will give you the results you want. Trust me, I've looked at every single option for the past year. The issue is the corona rings on the f01; they're not designed for LED bulbs so what happens is the the rings are prefect at night but during the say they're not visible, this is due to the design of the rings and there's nothing you will find on the market will fix this issue. Only fix is if you retrofit the LCI headlamp but the cost isn't worth it.
I got fed up and went with PIAA's, the PIAA's got rid of the piss yellow color but that's about it.
      03-08-2013, 09:02 PM   #3
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
Im using the letronix kit from Germany. It throws error codes, but not all the time.
You can see pics in my other thread.
      03-09-2013, 10:59 AM   #4
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
The PIAA's sound like the way to go. Any info on which ones/color? Pics?
[Update]: PIAA's ordered.
      03-10-2013, 03:35 AM   #5
335ifanatic
51
I'll try to snap pics tomorrow but basically the bulbs project a whitish/yellowish light instead of the piss yellow you get from the stock bulb but at night they look yellow but not as bad as the oem bulb.
      03-15-2013, 05:10 PM   #6
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
Well, I went and ordered the PIAA Xtreme White H8's
This is the result, not too dramatic of a difference, but it definitely takes the yellow out of the ring. Good enough for now...
The first shot is of both PIAAs in. The second shot shows a comparison with the driver's side being PIAA and passenger stock.
      03-19-2013, 02:50 PM   #7
AlBoston
Drives: 2019 740i xdrive & 2018 640GT
I ordered Phillips Diamond Vision 5000k H8 halogen bulbs. I'll post pics, I get them on Thursday.
      03-20-2013, 10:05 AM   #8
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
Nice. I was debating between those and PIAA. I'm thinking of switching, if the Phillips end up being better.
      04-21-2013, 01:17 PM   #9
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Here's my review of the mTEC V2.
http://www.7post.com/forums/showthread.php?t=831034
      05-20-2013, 01:03 AM   #10
frieseke
Drives: BMW 750li
How much would it cost to retrofit the LCI headlights? Has anyone done it? I wonder if they'd still throw codes? Is it a one way trip or could you go back afterwards? The real trick would be getting the new LCI LED headlights.
      05-20-2013, 11:59 AM   #11
DBV
DBV's Avatar
779
2023 BMW M2  [8.75]
Probably reversible, however the cost is prohibitive. My guess is ~$3000 all said and done.
      05-20-2013, 04:06 PM   #12
335ifanatic
51
LCI has already been done, it'll cost upwards of $4000 because you'll need to swap out a module as well.
