      06-24-2023, 09:12 AM   #1
J_Spool
J_Spool's Avatar
Drives: E92 335i E60 535i
120408 DTC
So I’m dealing with a 102408 code that clears when I turn car off and comes back whenever it wants apparently. Throws car into limp mode and no other code present. Before this I was getting a 12B505 code for O2 sensor which I replaced both for good measure and reset adaptations cleared all codes and all was good…. For a bit. Now I just keep getting this solo code and it’s driving me nuts.
Anyone every dealt with this code or pointers on wtf is going on lol. Car is a 2016 BMW 750i with the N63R aka tu2 engine.
Thanks for any input in advance
Happy boosting
      06-25-2023, 06:31 AM   #2
Raimo5
Drives: BMW 740d xDrive (G11)
What does code 102408 refer to? Is it a boost control error?
      06-25-2023, 07:16 AM   #3
LuckyW
LuckyW's Avatar
86
Drives: BMW 520d M Sport
Fault Code Description
The diagnosis monitors the switching off of the charging pressure control by the DME.
Fault monitoring conditions:
Fault handling is performed by a different fault memory entry of the charging pressure control.
Fault Code Conditions
General Conditions Temperature precondition:
- See individual fault.
Time precondition:
Other preconditions:
Control unit voltage: 9 V to 16 V.
Terminal Condition - Terminal 15 on
Terminal Condition - PWF status: Driving
Driving Conditions Note: The designations of terminal status or PWF status apply according to the vehicle electrical system of the vehicle.
Fault Time Condition
The fault is entered immediately.
Service Plan
- The fault entry is for information purposes only.
- Measure for rectification: Work through all the individual faults that have an effect on the charging pressure system and the charging pressure control.
Fault Impact
- The engine operates in its emergency program.
- Power reduction.
- Trip can be continued.
Warnings
Warning Lights CC message
Control Center Messages
Service Notes
Deactivation of the charging pressure control to protect the engine. The error is caused by another error for the charging pressure control or by an error for another component.
      06-25-2023, 10:06 PM   #4
J_Spool
J_Spool's Avatar
Time precondition:
Service Plan
Fault Impact
- Power reduction.
Warnings
Service Notes
Well he nailed it lol. But the dumb part is I have no other code so I’m stumped on wtf is triggering limp mode lol
      06-26-2023, 09:30 AM   #5
Raimo5
Without seeing FASTA or live data, it's hard to say, but I would lean towards wastegate solenoids.
This kind of fault usually manifests itself when everything in engine compartment becomes heat soaked and those actuators start behaving funny. Everything within controller feedback loop might seem within spec for electronics, but actual boost deviates from the setpoint and is thus disabled/degraded.
EDIT: From another thread I see that you run some kind of tune on your engine. This might very well cause your issues.
      04-11-2024, 02:32 PM   #6
johnrobertyoung7
Drives: 2016 BMW 750i, 2013 BMW 335i
Hey did you ever get this figured out? I am in the same boat as you with a 2016 750i, only has 35k miles on it right now. I will randomly get the 120408 code (do not get any other codes with it) and my car sometimes goes into limp mode. Will usually reset once I turn off the car.
